Question about Viking Spray Gun: High Pressure Spray Gun 7. 5 Cfm, Fluid Tip Size: 1. 8mm. Air Inlet: 1/4",70PSI
Spray gun support
Are there any recommended maintenance measures?
    President:
  • 2,712 Answers
Daily clean-up all parts with proper cleaners/solvents. Re-lubricate where lubricant is washed away by cleaning. Moisture traps and compressor tanks must be drained daily.
Posted on Aug 27, 2008
I agree with Tina. In addition I have some further information. this refers to conventional and HVLP spray guns (NOT electrostatic equipment)
Needs the air cap also cleaning?
Yes,it does. Remove the air cap (sometimes called air nozzle) from thegun and immerse in solvent, use a brush. For the small holes use atooth picker or something soft enough (not a wire or other metals).Use compressed air to dry. The same procedure with fluid nozzle andfluid needle. Don't forget to lubricate the gun afterwards with anormally non-silicone grease (check your manual for confirmation).
The cleaning of the gun is not a bigissue. But the cleaning and maintenance of the spray system (tank,hoses, etc...) needs some “techniques”
Posted on Feb 11, 2009
Tippmann bt4 combat maintenance
Take a spray bottle filled with soapy water and spray it on the gun to find where the leak is coming from. Also, make sure there is an O ring on the tank.
May 07, 2013 | Paintball BT 4 Combat Marker
We are using an a Campbell Hausfeld Airless Spray Gun and wondering where to buy a new nozzle should it not last for the whole house? We live in South East, SA
the nozzle should last as long as it is cleaned properly when the day is finished. Walmart sells Campbell equipment and/or many hardware stores do as well, the tip may not need to be specifc to your brand to fit, take the tip with you when go shopping. Also, check with your Cities maintenance department and find out where they buy there tools and parts, most likely you will find the parts you need there.
Mar 22, 2011 | Campbell Hausfeld Airless Spray Guns &...
Unit does not draw from bottom cup
Both are gravity type spray guns, i.e. they cannot draw from a bottom (suction, siphon) cup.
Jul 25, 2010 | HVLP 2 DeVILBISS Auto Paint SPRAY GUNS...
Bubbles coming in to paint pot on my gavity feed gun please can you tell me how to solve the poblem
each time i have had trouble with my guns it will be trash or something keeping a seat from sealing off
Feb 12, 2010 | DeVilbiss FinishLine Gravity Feed Spray...
I have d51844 stick nailer, the problem is has a
2 things to check
1. when was the last time you oiled the gun, without proper lubricant, the driver will not return properly and that will impede fastener feed
2. have you cleaned the nose of the gun? try spraying it with WD40 or some other spay lube after using a spray cleaner, such as B12 carb cleaner or brake cleaner
Dec 09, 2009 | Measuring Tools & Sensors
I have just purchase a Wagner W550 electrical spray gun. Not having used one before I need to know how do I know if the coating mayterial need to be diluted and if so by adding how much solvent. I intend...
Have a look at the instruction manual. It should state the viscosity that the paint should have. Use a viscosity cup to measure the time the paint takes to drain from the viscosity cup. Dilute the paint if it takes too long.
Nov 24, 2009 | Wagner Air Tools & Compressors
Not enough compression to spray thompson water
Maybe just plugged. If it has the nozzle that can be rotated 180 degrees, roll it and try to spray. Sometimes a bit of debris gets in there and stops it up. If no on the rotatable nozzle, take the tip off and try to push liquid back to the container, or a waste bucket, to clear the line. You also may need to clean the tip. One last item.....since you sprayed water.....if you chased the water with the TWS, you may have made an emulsion. If so, remove the spray gun, and turn on the pump, pumping into a waste container, until the emulsion is displaced. Clean the gun. I'd say that if it'll spray water, TWS would be even easier.
Regards, --W/D--
Aug 03, 2009 | Wagner Air Tools & Compressors
Spray guns
hey do not see any answers so here you go -First I am not an apprentice on this matter- I spray cars as a hobbie- controls can be determined this way-follow these steps look at the trigger typically the needle that is lowest on the handle will be the air -top most will be paint.Paint will be adjusted by feel- the air is easy to adjust-back the knob off all the way- hold trigger on fully depressed(without being hooked to air) turn knob until you feel it touch trigger-stop- this is now adjusted.
I do recommend you lose the syphon system -gravity will sevre you better- you will use less paint and it is better for enviroment.
Go to web site for new book- best of luck -I will watch for you- what are you trying to paint?
Aug 31, 2008 | Air Tools & Compressors
Spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Aug 27, 2008 | Grizzly H7670 Mini Hvlp Spray Gun,...
Viking Spray Gun: High Pressure Spray Gun 7. 5 Cfm, Fluid Tip Size: 1. 8mm. Air Inlet: 1/4",70PSI Logo
550 people viewed this question
Top Viking Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Viking Air Tool and Compressor Expert? Answer questions, earn points and help others
