Question about Grizzly H7670 Mini Hvlp Spray Gun, Stainless Steel Cup
Spray gun tips
Are there any spare parts I should hold at my workshop?
    President:
  • 2,712 Answers
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Posted on Aug 27, 2008
    Problem Solver:
  • 5 Answers
A gun repair kit, (but probably a spare gun would be better instead of this. u wouldnt want to repair your gun at middle of painting a car)
gun cleaning set. gun grease (non-silicon based lube) its used for lube the gun after a good clean
Posted on Sep 07, 2011
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
We are using an a Campbell Hausfeld Airless Spray Gun and wondering where to buy a new nozzle should it not last for the whole house? We live in South East, SA
the nozzle should last as long as it is cleaned properly when the day is finished. Walmart sells Campbell equipment and/or many hardware stores do as well, the tip may not need to be specifc to your brand to fit, take the tip with you when go shopping. Also, check with your Cities maintenance department and find out where they buy there tools and parts, most likely you will find the parts you need there.
Mar 22, 2011 | Campbell Hausfeld Airless Spray Guns &...
I need a 1.8 tip for the husky pro spray gun .. i bought from home depot they do not carry tips. thanks john
devilbiss has a internet web site for repair parts ( also try graigs list you can find most anything on there)!
Jan 18, 2011 | DeVilbiss 1.8MM FLUID TIP # GTI21318
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
Spray gun wont stop spray when trigger is released
There is an adjustment nut on the back of the neddle but most likely is it wasn't cleaner the last time it was used. Take off the tip houseing then re move the nut on the front of the gun thats the seat for the carbide ball on the front of the neddle re move the neddle and clean all parts in laquor thinner then it should work
Dec 17, 2010 | Wagner GX10 Spraytech Airless Spray Gun...
Craftsman spray gun (919155190) tip is leaking fluid when trigger is NOT depressed. This happens at 8psi as well as 40psi. If I turn the fluid control knob "off", then there is no leak. If it is even a...
The tip as well as the pressure, are regulated in part be the viscosity and consistency of the product being sprayed. If the orifice is clogged, then it will not shut off properly and will cause splotchy spray when turned back on.
If the mixture is not smooth, the lighter part will leak out while the heavier parts remain behind... This of a lumpy gravy, the lumps hold the orifice valve open while the gravy leaks out.
Remix your solution, and pay attention to the viscosity requirements for your tip.
Good luck and don't forget to vote.
Oct 12, 2010 | Craftsman Air Tools & Compressors
After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
Mar 17, 2010 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Worked for about 10 minutes
do you have a gun that comes apart? alot of them have that filter in the gun that clogs up with latex.you could remove gun and soak in mineral spirits if it does not have that filter.
Sep 05, 2009 | Campbell Hausfeld Airless Spray Guns &...
Grizzly H7670 Mini Hvlp Spray Gun, Stainless Steel Cup Logo
576 people viewed this question
Top Grizzly Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Grizzly Air Tool and Compressor Expert? Answer questions, earn points and help others
