Question about Woodland International Chipper Knife for Bailey's BC6 Chippers
Digger how to
How to Use a Post Hole Digger?
    President:
  • 2,712 Answers
Hammer rebar into the ground to create pathways for water. Grab a hose and soak the ground to soften it before using the post hole digger. Wait until the water has had a chance to soak in. Raise the post hole digger and drop it, jaws open, into the ground. The jaws will cut into the ground and soften it even more for removal. Continue to use the weight of the post hole digger for the hard work, circling around the edge of the hole. Drop the digger down with force once you've loosened up a circle of soil. Open the handles to grab a bite of earth in the jaws and lift it out. Continue with Steps until you've removed all the loose soil, making a hole 1 foot in diameter.
Posted on Aug 27, 2008
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
Post hole digger gearbox oil leak
If the instructions do not give you an answer to your question and you can't find any information from the manufacture I would proceed as follows. The oil coming out of the breather is due to the splashing of the oil and the heating of the parts as they work building up pressure. I would tend to believe that as long as there is some coming out there is enough oil to take care of the gearbox.
If there is a separate plug to remove to add oil to the gearbox I would use that as my fill level. I hope this helps.
May 11, 2014 | Garden
Post hole digger wont run
Simple questions first...clean gas?
Good spark?
Fuel feeding?
Aug 15, 2013 | V-Twin Horizontal OHV Engine with Electric...
Post hole digger wont start run
Change the spark plug. Check the plug socket and look for rust or grime.
Homelite post hole digger
sadly no we can not .
Jul 18, 2013 | Garden
I get no spark
I get no spark is very vague! But if you tried a new plug and you still do not get spark, your coil is no good change it.
Apr 07, 2010 | General Auger Post Hole Digger 160CC Honda...
Digger support
Search local home and garden stores to find a post hole digger. Many department stores sell post hole diggers too. A local greenhouse or tractor supply store is also a good place to look for a post hole digger. Decide on he type of digger you'll need for the job. Although post hole diggers come in different sizes and types, they generally dig the same size hole. Know that it takes a lot of strength to dig holes with a post hole digger, but there are a diggers available with special features that allow someone not quite as strong to use the digger too. Pick up and examine the different post hole diggers while you're shopping. Compare the feel and weight of the tools. Pretend to dig holes and see how it handles. Compare the features and designs of different post hole diggers. Most are manufactured from fiberglass or steel, but some have a different shaped handles for specific digging jobs. Determine if you'd rather have a fiberglass handle or a wooden one. Fiberglass is lighter and more resistent to sun damage than wooden handles. Select a post hole digger based on your preferences, the job required and who'll be using the tool. Plan to spend more on a post hole digger that's made from steel or for heavy duty use. The range for a post hole digger is generally under $50.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Woodland International Chipper Knife for Bailey's BC6 Chippers Logo
310 people viewed this question
Top Woodland International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Woodland International Garden Expert? Answer questions, earn points and help others
