Question about Casio Cassiopeia E-125 Pocket PC
Cassiopeia Commited Suicide
My Casio Cassiopeia E-125 went and offed itself it seems. Saturday (couple days ago) I was using it a bit with acrobat and it got a little warm, but nothing unusual. Then it turned off on me. The only way I could get it to turn on was to do a complete reset. But, now that doesn't even work. It makes no difference if its on batteries or on AC, it still won't turn on. Is there anything I can do to fix it or is it trash?
    Master:
  • 551 Answers
Re: Cassiopeia Commited Suicide
There is reset and hard reset on many units, did you do both. You might try pulling the battery out for an hour or two and try it. Other than that open the back and look for dead bugs :-) actually not much you can do inside unless you have a parts source and Casio units are kind of like without parts - I emailed for some two weeks ago and never did hear from them - which is normal - it has happened numerous times before on other subjects including parts.
Posted on Sep 06, 2005
0 characters
3 Points
Screen goes out periodically
screen went into sleep mode. you can set the time in system manu some where.
Oct 24, 2007 | Casio Cassiopeia E-125 Pocket PC
Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
My Cassiopeia came with a 4 digit pass code on it from another user how do i get that off of the computer so i can use it
Casio claims that once a password has been set in your unit it can't be reset without losing all data. You can try resetting and see if that works. Use ur stylus and press the reset button for about 3 seconds.
Dec 23, 2006 | Casio Cassiopeia E-125 Pocket PC
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
http://youtube.com/watch?v=l0TT5CnbwBQ
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 connecting to Siemens ME 45
There are 2 things you could try. If you have a serial data cable for both the devices try using a nul modem (Casio part # SB-91 includes best nul modem ever made ) & select Hayes compatible on serial port on E-125. If you have a built in modem in ME-45 it should work. Similarly you could use MS Outlook as an intermediary for transferring your E-125 telephone numbers to ME-45.
Cassiopeia E-125 & Nokia 7650
You will need 2 things. Software to load on your E-125. The included Cd with your Nokia should have it. You will need a special cable to connect Nokia to E-125. I don't know where you will find it easily. There is a firm in Finland which makes all kinds of cables to connect different models of Cassiopeias to different models of mobile phones - essentially Siemens, Nokia & Ericsson. They run about US$ 50/= Last time I saw their listing it was 4 pages long. You might have to do some searching on the net or contact Casio for information. Hope this helps.
E-125 Owners BEWARE!
Unless a Casio technician has looked at it don't take Casio's word for it. There is an inverter PCB which converts the DC to high frequency AC for the fluorescent back light. lamp. This is available & can be repaired / replaced. There is also an issue with the E-125 backlighting which simply requires resoldering of a connector on the main pcb. Then there is the fluorescent lamp itself which can go bad & may be replaced. So DO take your device to a well equipped competent technician to look for the precise problem.
Casio Cassiopeia E-125 Pocket PC Logo
63 people viewed this question
Top Casio PDAs Experts
k24674
Are you a Casio PDA Expert? Answer questions, earn points and help others
