Question about Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br
Pump troubleshooting How do I know what size sump pump I need?
    President:
  • 2,712 Answers
What you need to consider is horsepower not size. The horsepower requirement for a house is determined by the area of drainage connected to the sump, the depth to the groundwater, the depth of the basement, and a few other factors. A 1/3 hp pump is standard for most houses.
Posted on Aug 27, 2008
Will a sfs1000/7 work with model 59025 solar heater?
The size of the pool and the size of the filter will play a role in the compatibility of your new swimming pool heat pump. We want to make sure that you have a swimming pool system that would be able to deliver the minimum gallons per minute of water that the new unit would need. We can check compatibility but we would need to know the size of the pool first. Please feel free to email us at splash@backyardocean.com so we can provide further assistance.
Jun 10, 2014 | Backyard Ocean SFS1000/7 Skimmer Pump
How long can I use my adapter to run my sum pump before draining my vehicle's battery
Be sure that the inverter can handle the load of the sump pump.
The vehicle should be running while the inverter is in use unless the sump pump only runs maybe once every other hour or so. Make sure you don't run the vehicle inside an enclosed area like a garage even if the door is up. Exhaust fumes may still get into the house. This inverter size is barely large enough to handle a standard sump pump.
Aug 27, 2011 | Powerline 0900-73 Slimline Inverter
Sump pump does not run. This happened once before and at that time the plumber got it going and said that the problem was in the switch. Now the sump basin is full and another plumber said that the pump...
rent pump & pump out water.. Then pull pump and get info off the ID tag and look for new pump or have some one check the pump to make sure it is the pump or a elec. problem.????
Oct 21, 2010 | Plumbing
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
May 14, 2009 | Plumbing
Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
May 05, 2009 | Black & Decker Husky 750w Power Inverter
Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Aug 29, 2008 | Kenmore 22062 Top Load Washer
Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br Logo
157 people viewed this question
Top Belle Group Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Belle Group Hammering Expert? Answer questions, earn points and help others
