Question about Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br
Fuel Pump how to
How to Change the Mechanical Fuel Pump on my Car?
  • 2,712 Answers
Things You’ll Need: * Socket wrench * Ratchet wrench with universal joints * Screwdriver * Pliers Remove the Old * Step 1: Disconnect the battery cables. * Step 2: Relieve any pressure in the fuel tank by removing the fuel cap. * Step 3: Unfasten the fuel lines from the pump. Be sure to wipe up any fuel that spills immediately. * Step 4: Remove the bolts that are holding the pump onto the mount and remove the fuel pump. * Step 5: Clean off any gasket residue that remains on the mating surface of the framework. Install the New * Step 1: Apply a layer of gasket sealer on both sides of the new gasket and put gasket over the bolts. * Step 2: Install the new mechanical fuel pump onto the engine. The rocker arm of the pump needs to be against the eccentric inside of the engine. * Step 3: Attach the fuel lines to the fuel pump. Reattach the lines to the carburetor. Use a wrench to make sure it is tight. * Step 4: Reconnect the battery ground cable. * Step 5: Start the vehicle and check for leaks.
Posted on Aug 27, 2008
How do I remove and replace the fuel pump on a 1978 Chevette?
Hi Dan,I use to have a couple of Chevettes,great on gas,Here's a link on your fuel pump removal,never had a issue with that,on these,you have to change the timing belt every 3 years ,the belt will stretch and jump time and the plugs will get fouled,here's another link on your timing belt if the fuel pump replacement doesn't work,also check your spark plugs. Repair Guides Carbureted Fuel System Fuel Pump AutoZone com Here's the timing belt link. Repair Guides Engine Mechanical Timing Belt And Sprockets AutoZone com
Dec 10, 2014 | 1978 Chevrolet Chevette
How to change 1984 chrysler new yorker 2.6l from an electric fuel pump to a mechanical fuel pump.
Replace the mechanical pump with a new unit and that will remove any reason of broken/failure from the equation. Remove the electric pump altogether and leave 1 filter in the line before the mechanical pump. Mechanical pumps are not in favour with some people who have no idea that they can be adjusted to give more pressure and greater volume for the bigger capacity engines. Some mechanical pumps are more expensive to repair / replace but if you price an electric pump to supply the volume that a properly adjusted or a larger capacity mechanical pump then the cost saving is minimal. Unless you get a fuel filter that is rated with a smaller micron rating than the standard filter any number of filters will not work as the smallest particle will get through the lot
Nov 21, 2013 | Cars & Trucks
We had our fuel pump changed but noe the car inside stinks of petrol we think the o ring is not put back properly is this dangerous or can we still drive the car as we cant afford to get it fixed
1984 Nissan Sentra? I believe this fuel pump is mounted on the engine, thats a mechanical fuel pump, you sure its not a 1994? If its a 94, you can change the o-ring yourself if you're up for it. On 94's the pump is mounted under the back seat through an access panel via 4 phillips screws.
Nov 11, 2013 | 1984 Nissan Sentra XE
I have a 1986 chevy K10 350 carberated that has a fuel line problem from the mechanical fuel pump up to the carb. its not pumping any fuel up to it, i've replaced the mechanical fuel pump and the
By automatic I'm assuming you mean electric. Are the hoses still plumbed into this pump and then to the mechanical pump? If so, disconnect from the electric pump and plumb together with a barbed fitting. It's a possibility that the electric pump is locked up and the mechanical pump can't pull fuel through it. Also, is the mechanical pump actuator rod in place behind the pump? This rides on the cam to actuate the pump.
Sep 07, 2012 | 1986 Chevrolet Chevy
What is the benifit of having an electrical fuel pump compare to a machanical pump, because I am ready to replace mine to a mechanical on my 1965 mustang
with an electric fuel pump you don't have to prime the system before start up, and you can control fuel pressure, if your car is stock the mechanical pump will do fine
Feb 17, 2011 | 1965 Ford Mustang
Cant locate fuel pump
the fuel pump is located inside the fuel tank, the fuel tank must be removed to change the electric fuel pump.
Apr 26, 2010 | 1995 Mitsubishi Mighty Max
I have a 1964 oldsmobile super 88. where is the fuel pump. it has an electric pump underneath. however i replaced it and the car ran for a day. now there is no fuel to the carb. thinking of .....
OEM fuel pump was mechanical, driven by the cam and is bolted to the block
if with the replaced electric fuel pump still no fuel, then check power and ground remove the output line and check for fuel there
possible clogged fuel filter... the one mounted on the carb and/or in the fuel line to the carb.... yes there should be TWO filters!
Mar 18, 2010 | Oldsmobile 88 Cars & Trucks
Where is fule pump at on a 1985 ford ltd
Oct 06, 2009 | 1985 Ford LTD
Has fuel and spark died on me will start with carb cleaner
If the car has a mechanical fuel pump,the diaphram in the pump is shot.The pump would run off the cam and with the leak,fuel will go into the sump.Its an easy fix and may take an hour.If its not a mechanical pump,sorry.Hope this helps
Sep 16, 2009 | 1997 Chevrolet Tahoe
The engine turns but the car won,t start.
You will need to check for fuel pressure or dirty filter. If you do not have fuel pressure; be sure to check fuses or any relay pertaining to fuel pump (if electric). If fuses and relays are good check or replace fuel filter. If the fuel pump is mechanical disregard fuses & relays and check or replace fuel filter. If this does not resolve the problem then the problem could be the fuel pump if mechanical, If its an electric fuel pump it could be a fuel pressure regulator, fuel pump, crimped fuel line or other wiring issue.
These are the most common things I run across, oh, a crimped fuel line can cause the problem in either case electric or mechanical. Hope this helps in some way, been awhile sense I worked with an older car.
Apr 05, 2009 | 1986 BMW 5 Series
Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br Logo
142 people viewed this question
Top Belle Group Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Belle Group Hammering Expert? Answer questions, earn points and help others
