Question about Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br
Pump support How Do I Replace a Sump Pump?
    President:
  • 2,712 Answers
Follow these steps to replace a malfunctioning sump pump. If you are starting from scratch and want to put in a completely new sump pump and drain line, you should have a professional plumber do any actual piping unless you have an advaced knowledge of those techniques. Locate the sump pump in your basement. Unplug it to avoid possible electrical shock or personal injury. Find the place to disconnect the pump from the drain line. This is usually either a screw-together type union or a rubber coupling with hose-clamp fastenings. Both are quickly and easily undone. Remove the pump from the pit and allow it to drain for a few minutes. Any plastic piping or fittings that comes from the water outlet opening and goes up to where the pump connected to the drain line needs to be removed and saved to reattach to the new pump. Take the pump with you to your local hardware store, plumbing-supply house or home-improvement center. They can help you pick a replacement that requires the same power source and provides the same drain-line hookups and pumping capabilites. Reattach any piping and fittings in the same way that they were on the old pump. Set the new pump in the pit and reconnect the union. Plug in the pump. You can test the pump by filling the sump pit with buckets of water.
Posted on Aug 27, 2008
UTILI TECH SUB PUMP NOT TURNING PUMP OFF
Switch is stuck or defective. probably be safest to change switch since you do not need a flood
Easy fix for sump pump that will not shut off
How to replace sump pump float switch
Jan 31, 2016 | Office Equipment & Supplies
How do I replace a dishwasher sump pump gasket?
Would love to help but need manufacture and model #
Jan 28, 2015 | Dishwashers
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
How to replace a oil pump no a ford ranger with a 4.0
Raise engine off mounts remove sump bolts the pump is inside the sump.
Aug 19, 2014 | Cars & Trucks
CHANGING THE OIL PUMP ON AN 2000 BUICK CENTURY
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html
Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 15, 2012 | 2000 Buick Century
How do i replace the sump in a samsung dishwasher?
This is not as bad as it looks, the Pump motor is more challenging. If your sump needs to be replaced then do the following. Unplug the unit, shut off the water, and remove the racks. Next remove the wash pipe that goes from the sump to up the back and over the top, it just pulls out but be gentle. Next remove all the screws on top of the screen and pull that out. You will see a gasket seal that is either stretched or broken. Next remove the white Pump wheel by turning the screw clockwise (the threads are reversed so it does not unscrew when the pump is running). Now pull up on the grey plastic wash pump housing. You will see the grinding blade that pulls off the wash pump motor shaft. There is your sump. If you need to change the pump you'll have to turn the unit over. Chances are all you'll need to do is really clean out the sump and replace the stretched out seals, available online for about 15.00 or so. Reassemble and start washing. good luck.
Jan 26, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
Replace oil pump on a 1993 jetta celebration 3
The oil pump is located into a sump.Loose all the screws around the sump but the first drain the oil.You need also new sump gasket.
Apr 23, 2010 | 1993 Volkswagen Jetta
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
May 14, 2009 | Plumbing
Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br Logo
184 people viewed this question
Top Belle Group Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Belle Group Hammering Expert? Answer questions, earn points and help others
