Question about Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br
Breakers Troubleshootinf Which type will be best for breaking oversize materals?
  • 2,712 Answers
When breaking oversize material the breaker is expected to break the material down the middle into two pieces. This is optimum production. If the operator has to re-position the breaker towards the edge of the rock and gradually downsize the material, production rate slows down. To assess what size of breaker will effectively handle this application, the size and hardness of the material must be known. If a 4 cu. yard piece of hard rock (20,000 psi or greater) needs to be broken in half you will require a 7,500-ft. lb. or larger breaker. If a 2 cu .yd. piece of limestone (20,000 psi or less) needs to be broken in half you will require a 3,000 - 5,000-ft. lb. breaker.
Posted on Aug 27, 2008
I have a feh-015 that is in a small home with 5 registers, came from factory this way and way oversized can I run heat on first stage only?
15 kw is actually 3 stage/3 elements. Yes this would be possible depending on how handy you are. If you were to inspect your heater all 3 elements have limit switches that would turn the element off if it got too hot. Identified by a temperature rating written on the switches. Unhook one side of two of these and be sure to wrap the wire well with electrical tape. BE SURE POWER IS OFF BEFORE OPENING CABINET!!! Once complete you can always verify your amp draws each element typically draws 20 amps. Be sure your checking each line voltage. Likely have 2 breakers for a 15 kw heater, 60&30. Good luck
Feb 23, 2017 | Heating & Cooling
Does G E make 1pole 20amp wifi circuit breakers
Not sure of what you're asking (Wifi?). There are 3 main types of circuit breakers. The standard, the arc fault, and GFCI type breakers.
Sep 13, 2016 | Electrical Supplies
Where to get Oversize Caskets ??
cant find one, make one
Aug 18, 2015 | Miscellaneous
Where can i find a spider gasket for multiport valve
Gasket materal can be purchased for most auto parts stores. Just match the type of materal and use the valve or old gasket as a pattern.
Jun 30, 2014 | Blue Wave SandMan Deluxe Above Ground Pool...
What is the difference between standard size main bearing and oversize main bearing. Which is best for the 5.4L V8 engine
thats a good un? ok standard bearings are a standard size,,,over size bearings are smaller in the center to make up for the metal that has been removed from when the bearing was re-fased
ie: ground down to smooth it off so its flat again,,,,,now you can fit oversized bearings on a standerd bearing becouse they would be far to tight and would lock the bearing up,,,,so you need to re-grind the bearing serfice or fit standerd bearings back in,,,only if the shaft is a good one?
i hope this has help you out
Nov 28, 2010 | 1997 Ford Expedition
(1) List of standard fuses (2) Calculation
I can help here but need more information. In all cases you need to know what load is "downstream" from the breaker or fuse. You do not want to put in one that is too small but also, and more importantly, one that is not too large. Can you ask a more specific question?
Oct 28, 2009 | Electrical Supplies
I have a suzuki vitara 1991 i just bought whos ignition is damaged, where can I find one in good condition?
If you go onto yahoo or google and type in "car breakers" they will give you a form to fill in and contact a load of breakers. The breakers will then let you know who has the parts you are looking for and the price. Best of luck.
Jun 05, 2009 | 1999 Suzuki Vitara
Power steering pump
the best thing you can do is redrill and tap oversize bols into the block
Feb 16, 2009 | 1995 Buick Park Avenue
Breakers support
When breaking Concrete, the breaker is expected to penetrate the material, allowing it to crack and shake loose from the reinforcing steel. High frequency breakers tend to provide better performance in this application as it is not the energy per blow, but the fast blow rate that destroys the concrete's structural integrity. We recommend on concrete walls, footings, and floors to use a 750 - 1,500-ft. lb. breaker. With larger projects, consisting of large footings greater then 4 cu. yards, use a 2,000 - 5,000-ft. lb. breaker. The high production demand of bridge and building demolition requires a 7,500 - 10,000-ft. lb. breaker.
Aug 27, 2008 | Northwest Smith Cooper 3/4" Hose End...
Breakers advice
When trenching, the breaker is expected to fracture a solid mass of rock into manageable pieces. The size of the material could be 100's of cu.yds, and the energy will be quickly absorbed. This is why it is recommended to work from a bench so the rock has somewhere to break out. We recommend when trenching in limestone or medium hard rock, to use a 3,000 - 5,000-ft. lb. breaker. When working in hard material we recommend a 7,500 - 10, breaker, and if high production is critical, a 13, breaker would be beneficial.
Aug 27, 2008 | Belle Group BHB30 - for 5 gallon Hydraulic...
Belle Group BHB30 - for 8 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br Logo
189 people viewed this question
Top Belle Group Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Belle Group Hammering Expert? Answer questions, earn points and help others
