Question about Lisle 2 to 7in. Glaze Breaker Engine Cylinder Hone
Breakers Question What kind of sizes are out there?
  • 2,712 Answers
This is the most critical factor in choosing the breaker size. SMALL HYDRAULIC BREAKERS (HAMMERS): up to 1200-ft.lbs. (1627 Joules), are typically used in concrete and other light duty work. MEDIUM HYDRAULIC BREAKERS (HAMMERS): 1200 - 4000-ft.lbs. (1627 - 5423 Joules) are used in both concrete and rock applications with limitations on the size and amount of material to be broken. LARGE HYDRAULIC BREAKERS (HAMMERS): over 4000 ft. lbs. (5423 Joules), are typically used in rock and large scale concrete demolition projects.
Posted on Aug 27, 2008
What size breaker goes into the unit
it depends on what you are talking about,if you need a circuit breaker in the transfer switch,then you cant go over what the amperage of the generator is,if you need circuit breakers for the outlets on the generator,that also varies depending on your generator,if you would of given all the info that we need,i wouldnt have to give you this kind of answer,it couldve been more concise,make,model,s/n of generator,s/n of transfer switch etc.
Apr 16, 2015 | Electrical Supplies
What size breakers does this control panel require? I see the GFI interrupted, but it looks like its missing other breakers...
Look at your breakers... take photo... look at brand name on breaker box.
Go to local store and see if they have same-similar breakers.
Feb 11, 2015 | Hardware & Accessories
Is it acceptable to have 3 twin pull breakers in this box
If it was done by a licensed electrician it would be within code. The dependency is the load and the box rating. Obviously the current rating of the breaker is a concern as well as what is on it. If you have a low wattage circuit like on bedroom etc and split that with another one, it would be fine. But you should not put something like kitchen outlets on a split circuit.
Jan 05, 2015 | Electrical Supplies
I need a 2 pole half size arc fault breaker
If you are pressed for space in your panel, it would be easier to free up space in the panel by replacing some of your standard breakers with half size--or "piggy back"--breakers. The freed up space will permit you to install a standard arc fault breaker.
Aug 20, 2013 | GE Circuit Breaker THQP PlugIn 2 Poles...
Using 4 individual breakers tied together with bar accross switches, what size individual breakers will I need to use to use for a 200 amp breaker
50 amps for each breaker?
What are you doing?
Something sounds wrong with your question, and I see a code violation in the making.
Add a comment March 2013 and give more detail about what you are connecting to 4 breakers.
I am concerned about fire hazard.
Mar 27, 2013 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Ok, I have a half size GE 30 amp tandem breaker I want to install in place of a full size breaker to make room in my box. If I move it down one opening it will fit in, but not in the origional place of the...
Yes, but you should put in another half size breaker even if you don't use it so that you don't leave a hole in the front panel, unless you can find a half-size cover instead. I am puzzled about why the half-size breaker won't fit in the original spot. Maybe you are replacing a pair of full-size breakers that are linked together to provide 220V? If that is the case DO NOT replace these with half size breakers. Good luck.
Aug 05, 2012 | Electrical Supplies
Renting old house with old power box uses 'plug in fuses' , doesnt have cut off safety switch ,i heard that i can by circut breakers to stop any surges and plug them into fuse box ,does that sound right ?...
Wow, all due respect, but someone would really be negligent to offer you a solution to this problem. An electrical panel isn't something to mess with, especially if you're asking these type of questions. Contact a professional electrician in your area or run the risk of electrocuting (that's DEAD by electricity) yourself. Good luck, and please be safe.
Aug 10, 2010 | Eaton ARC FAULT CIRC BREAKER
How to setup a thqp250 in a box?
These breakers are 1/2 size and only fit in an area of a panel designed for these. The bus bars must have extra tabs for these breakers. Before 2008 you could only have 42 breakers in a panel, so only some of the slots were reserved for these. Secondly, since this is a two pole 220breaker it must be in two spaces. This leaves a 1/2 space above and below the breaker. You could add a single pole breaker above and below. Now compare these in size, is there any way they can be as good as a full size breaker?
Aug 04, 2010 | Connecticut Electric THQP250 General...
Bryant brd 30-30-30-30 quad replacement
You could get em here :
Why anyone would use a twin 2pole 30am breaker I'll never understand.
There is no way this size breaker could match up in quality to two full size 2-pole 30 amp breakers. If one wants to double up, do it with the 15-20 amp sizes.
Jul 16, 2010 | Bryant Westinghouse Bqc Quad Circuit...
Zenith IQB60M92W 60in Rear Projection
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Oct 01, 2005 | Zenith IQB60M92W 60" Rear Projection...
Lisle 2 to 7in. Glaze Breaker Engine Cylinder Hone Logo
188 people viewed this question
Top Lisle Hammering Experts
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
