Question about Ingersoll Rand 236 1/2" Air Impact Wrench
Wrench Problem What is the best way to use my air wrench?
    President:
  • 2,712 Answers
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Posted on Aug 27, 2008
5 Suggested Answers
  • 5 Answers
SOURCE: Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Posted on Apr 25, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
  • 50 Answers
SOURCE: impact wrench is not working
fill down the air pipe wit penatrating oil hold trigger and keep movin forward and reverse wen in frees up fill wit airtool oil
Posted on Aug 10, 2010
HansPP
  • 2510 Answers
SOURCE: I have a husky impact wrench, set at 100psi, but
There should be an air control valve adjacent to the air inlet, is it opened sufficiently. Failing that there is a problem with the drive motor. It could be seized bearing or a broken vane. There is nothing you can really be doing wrong, it is a very straightforward tool.
Posted on Jan 27, 2011
Thank You for the response.I guess I need a air Impact wrench instead of the DeWalt Electric
Or compare before with 18Volt Milwaukee FUEL impact wrench on Li Ion Battery [ try before you buy ] its having very much power.
But if you have work the whole day job the best choise for long lasting air tools
Mar 06, 2015 | Dewalt Tools & Hardware - Others
Repair wrench
This should help identify Parts for your zinger doll Rand #261 Air Impact Wrench...
Look here:
http://www.atecsarl.com/wp-content/uploads/2013/08/271.pdf
Apr 17, 2014 | Ingersoll Rand 3/4" Drive Super Duty Air...
Farmhand fht586
Robert,
From your description, it sounds as though the air wrench may be dry. What that means is that you need to oil the wrench through the air chuck attachment. Turn the wrench over and add several drops of air tool oil which you can get at most tool stores or home improvement centers. Then re-attach the air supply and try the wrench again. If the wrench has not been oiled for a long time, it's possible that the rotor or vanes are seized, in which case the tool will need to be dismantled and the vanes and/or rotor and bearing might need replacement. If that's the case, you'd be better off replacing the wrench. Make sure you have enough air pressure to run the tool. Air tools should be oiled frequently, expecially if they are used with un-dried compressed air or if they see heavy use.
One other thing - make sure the reversing switch is not in "mid" position and is either in forward or reverse.
Good luck sir
Oct 29, 2013 | Computers & Internet
Best method to remove engine compensating sprocket on a shovelhead
A good air wrench works fine. Sometimes if someone has put too much Loctite on the nut, you may have to apply some heat to the nut. I've run into a few of these that the cheap Chinese air wrenches would not take off. Heck, I've run into them that a Snap-On air wrench wouldn't budge. I bought one of the Ingersol-Rand Titanium air impact wrenches and it works on all of them. Very powerful 1/2" wrench. But, unless you're going to use it a lot, it's too expensive to do one job with. I suggest you trailer the bike to a tire shop and pay them a few dollars to take the nut off with one of their wrenches. You'll probably need to take the proper sized socket with you.
Good Luck
Steve
Jul 03, 2011 | Harley Davidson FLHT Electra Glide...
How do you oil a Craftsman Air Impact Wrench Model No. 875191182?
Just put 3-5 drops of air tool oil down the air inlet coupler and then run the gun for 5 seconds. Do this everyday that you run the gun for best results.
Feb 25, 2011 | Craftsman 1/2" Impact Wrench
Wont work in remove direction just blows air
fill it wit oil hold in triger and flick between forard and reverse should free up the vains inside
Jun 29, 2010 | Craftsman 1/2" Impact Wrench
The 734 cp impact wrench has not been used for a couple of years and appears in excellent considtion however, I do not remember how to oil and/or remember the impact ratings using the dial; is there a...
Put 4 or 5 drops of oil into the air line opening. Connect an air supply and burst the trigger a few times. The settings are 1-less 4 more. It's all up to the application and they are not specific settings.
Oct 10, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
When using the tool to loosening bolts my wrench
dont use wd40 or any of those kero basedthings in an air tool use automatic transmission fluid or buy air tool oil. the symptomyou speak of is typical of ther neoprene o/ring becoming hard and breaking up .my best advice is to take it to an airtool servic centre strange this is the second one of these in 5 minutes
Aug 18, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Wrench Support
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Aug 27, 2008 | Impact 3/4" Dr. Heavy - Duty Air Wrench
Ingersoll Rand 236 1/2" Air Impact Wrench Logo
232 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
