Question about Belle Group BHB30 - for 5 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br
Breakers advice Which type will be best for trenching?
    President:
  • 2,712 Answers
When trenching, the breaker is expected to fracture a solid mass of rock into manageable pieces. The size of the material could be 100's of cu.yds, and the energy will be quickly absorbed. This is why it is recommended to work from a bench so the rock has somewhere to break out. We recommend when trenching in limestone or medium hard rock, to use a 3,000 - 5,000-ft. lb. breaker. When working in hard material we recommend a 7,500 - 10,000-ft.lb. breaker, and if high production is critical, a 13,500-ft.lb. breaker would be beneficial.
Posted on Aug 27, 2008
What services are included in Get Vacced Vacuum Excavation of Australia?
Services included in Get Vacced Vacuum Excavation of Australia are given below:
a. Potholing
b. Excavation
c. Trenching
d. 3000, 4000, 5000, 7000 Litres waste ability.
To use the best services of this Vacuum excavation in Australia, you can visit Vacuum excavation Gold Coast.
Aug 22, 2017 | Vacuums
What is the volume of 13' x 3" into gallons
13' x 3" is a measure of area. Gallon is a unit of volume. There is no direct conversion.
Let's say you have a skinny trench 13 feet long by 3 inches wide. How many gallons of water is in the trench? That obviously depends on how deep the trench is.
Apr 24, 2014 | Office Equipment & Supplies
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Nov 20, 2013 | Shop Vac Vacuums
Realistic TRC-459 manual
  • Hi Marc. There really is no free users manual online for this CB. But if you go here http://support.radioshack.com/support_electronics/26577.htm there will be options you can click on. It's basically the manual split up into links. It will tell you everything about your radio and the pages are printable just the same. You will see what I mean.
  • Hope this helps.
Nov 25, 2011 | Radio Communications
I have a trench 1475' long, with three rows of 3'' pipe.
If the pipes are 3" outside diameter, the displacement is 24.15 cubic yards, however standard 3" pipe is 3.5" diameter, which would displace 32.85 cubic yards. 505.32 cubic yards is correct for the total trench volume.
Mar 23, 2010 | Plumbing
There is a trench/drain on the back wall behind
If you can view to rear of the unit wnd remove the bottom panel, there should be a hose coming from the drain to a pan of some type. If it has clamps on both ends remove the tube, place a vessel under the top tube attach point of trench drain and test the trench drain, if water is flowing freely from the drain to the vessel then clean out the tubing and replace.
Jul 16, 2009 | Refrigerators
I have a suzuki vitara 1991 i just bought whos ignition is damaged, where can I find one in good condition?
If you go onto yahoo or google and type in "car breakers" they will give you a form to fill in and contact a load of breakers. The breakers will then let you know who has the parts you are looking for and the price. Best of luck.
Jun 05, 2009 | 1999 Suzuki Vitara
Breakers support
When breaking Concrete, the breaker is expected to penetrate the material, allowing it to crack and shake loose from the reinforcing steel. High frequency breakers tend to provide better performance in this application as it is not the energy per blow, but the fast blow rate that destroys the concrete's structural integrity. We recommend on concrete walls, footings, and floors to use a 750 - 1,500-ft. lb. breaker. With larger projects, consisting of large footings greater then 4 cu. yards, use a 2,000 - 5,000-ft. lb. breaker. The high production demand of bridge and building demolition requires a 7,500 - 10,000-ft. lb. breaker.
Aug 27, 2008 | Northwest Smith Cooper 3/4" Hose End...
Belle Group BHB30 - for 5 gallon Hydraulic Pack 70 lb Handheld Hydraulic Br Logo
180 people viewed this question
Top Belle Group Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Belle Group Hammering Expert? Answer questions, earn points and help others
