Question about Speed CGW ABRASIVES 35606 "24 GRIT" HIGH SPEED GAS SAW CUT-OFF WHEEL 14"x5/32"x1"
Grinder support Which kind of blade is suited for which kind of job?
    President:
  • 2,712 Answers
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Posted on Aug 27, 2008
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
I am looking for a new blade for this product. Do you have them and what is the cost?
Compare the price of a new blade versus a new BURR grinder.
BURR grinders are more consistent for grinding coffee, blade grinders, you have to guess and some grounds will be finer than others.
This is the reason you don't see a BLADE coffee grinder for commercial applications.
There are some good home burr grinders (some with a timer) and not that expensive.
Jan 14, 2011 | Bosch MKM 6000 Electric Blades Grinder
HOW DO I REMOVE THE BLADE FROM A HEAVY DUTY MILWAUKEE SANDER/GRINDER, CLOCKWISE, OR COUNTER CLOCKWISE? Some tool at my wearhouse tightened the blade so much my boss and three other guys can't get it off to...
i am a registered Architect and all kinds and brands of angle grinder and even edger i've seen are to be loosened counter clockwise....even once i didn't encountered yet a clockwise loosened...unless that your grinder is so called to be an special one"?So for sure,you can READ the thread of the bolt of the lock of the blade to let you know what is the exact rotation.
Oct 27, 2009 | Saws
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Oster regency kitchen center meat grinder attachment
What exactly are you having problems? Setting up the grinder? The hopper inserts into the back side of the mixer head locks in place with a set screw. Then insert the piece that looks like an auger push it all the way back. next, comes the four blade knife it looks like this " + " if look at the center of the blade you will notice a square hole on one side place that side towards the auger. Then there are your grinder attatchments I only have two,one coarse, one fine. place one of them against the blades placing the tabs in the cutouts on the discharge end. mext there is a large metal cap thread this on the discharge. Set the control to grind and the speed to 10. You are set to go. cut the meat into strips or chunks that will fit down the infeed and use the plastic plunger to push them into the auger.
Oct 26, 2008 | Food Processors
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Speed CGW ABRASIVES 35606 "24 GRIT" HIGH SPEED GAS SAW CUT-OFF WHEEL 14"x5/32"x1" Logo
219 people viewed this question
Top Speed Saws Experts
Tom Chichester
ray gallant
Are you a Speed Saw Expert? Answer questions, earn points and help others
