Question about SAIT Portable Saw Cut-Off Wheel TM 12 x 1/8 x 1 BRUTE
Cut off question
What types of cut off saws are out there?
    President:
  • 2,712 Answers
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Posted on Aug 27, 2008
I can hear the motor working however the blade got stock when I'm cutting the wood, does any one here know what to do with that type of issue?
If you are using a circular saw, you are probably ripping hardwood lumber that was originally sawed (incorrectly) under stress. Back your saw out and start the cut again. You may have to do this several times until the lumber "relaxes" enough to be cut.
Nov 30, 2017 | Blade Saws
Slows down and stops when trying to cut hardwood
You just do not have a saw that has enough power, the blade is dull or both. Change your blade and push the wood through slower or get a more powerful saw for the hard woods.
May 11, 2016 | Delta Saws
Is there a steel cutting blade for genesis band saw model # GBS900
I got my band saw blades on sawblade.com. They customized blades and they offer different types of metal cutting blades.
Dec 03, 2014 | Blade Saws
CAN I USE A SEARS 12 INCH BAND SAW TO CUT MEAT. WHAT TYPE OF BLADE DO I NEED. DO I CUT THE MEAT FROZEN OR NOT?
That will work with the meat frozen or thawed, but the problem will be that the band saw will be very difficult to clean adequately afterwards. That won't be a big problem until a week after you have cut meat with it the first time. Once it stinks you won't want to use it cut anything! A meat-saw is made to be easier to clean than a wood or metal cutting bandsaw.
Dec 10, 2012 | Saws
New blades, new belt.. burning the wood when I try to maky any type of cut
Is the blade the correct one for the type of wood you are cutting?? There will be recommendations on the saw blade. Finer toothed blades are for plywood, etc. Aggressive or large tooth blades are for thicker wood.
May 15, 2012 | Craftsman 10" Table Saw
Useing my band saw i get burn marks
You are applying too much pressure to the saw blade...let the blade do its work...slow down a bit...the burn marks indicate too much heat is building up...the blade is not cooling nearly enough as it goes around, from too much pressure in the cut, or the band blade may be dull, too. When the blade overheats, it loses its strength and its ability to cut as well, and it will become dull much faster. Make sure the blade is the proper type---teeth per inch and type of teeth--for the material you are cutting. Take your time...you, the saw and the blades will last longer! Be safe!
Sep 16, 2009 | Saws
Replacing tungsten tips on saw blade
Best take it to a saw doctor or saw sharpener. They braze them on with a cold water high pressure jet. Also the type of tip you use is influemced by what material you are cutting. These guys are experts at this.
Jul 06, 2009 | Saws
Band saw not cutting square
Rather than type out the solution again I'll direct you to here: http://www.fixya.com/support/t1751837-jet_414458_hvbs_saw_saw_cuts_round
Mar 31, 2009 | Saws
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
SAIT Portable Saw Cut-Off Wheel TM 12 x 1/8 x 1 BRUTE Logo
262 people viewed this question
Top SAIT Saws Experts
Tom Chichester
ray gallant
Are you a SAIT Saw Expert? Answer questions, earn points and help others
