Question about Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS
Air Drill Troubleshooting
How should I keep the feed system in good shape?
    President:
  • 2,712 Answers
The feed system should be smooth all the way forward. For cleaning, wipe off the magazine or blow it out with air rather than using an oily lubricant. The lubricant actually attracts dirt and debris.
Posted on Aug 27, 2008
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
What would be the most likely cause for my lxph05 brushless LXT hammer drill to intermittently not turn?
check the position of the forward/reverse switch as if it is not properly positioned the current doesn't know which way to spin the motor
check that switch for loose wire or being faulty
Jun 11, 2015 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How can I square the table on my Skil 3320 drill press?
To get rid of the bad boring job on the column you might have to take the swivel adjust apart below the table and rework that. I would try to shim it rather than file all that cast iron. A stainless hemishpere shaped shim of .007" thickness or so would be a good thing to try first. Square with a good 6" square and a dowel pin in the chuck and the Column tensioner at full tightness of course. Keep the shim 1/2" out from the lock bolt and the whole thing should sort of tighten down well enough to use as long as you don't bend the handles with drill pressure. We had one that was actually loose between the Column, the Base and the Drill Head where it was turned too small.
Dec 16, 2011 | Skil 3320-01-RT Factory-Reconditioned 10"...
I do not like it when I get connected to this site. Good luck, hope all ya'all are making a living. DETAILS
Actually you get many tips from this website :
http://vikingdrill.com/Drill_Troubleshoot_Face.html
Below is Troubleshoot sample availabe in this web :
If you have problem with broken Drill because flutes clogged with chips, drill binds in hole (Common in deep holes) then solution are :
- Use a drill with wider flutes and/ or faster helix angle
- Consider polished flutes
- Withdraw drill at regular intervals to clear chips
- If chips are not broken up, consider heavier feeds - or a chip breaker design.
You can take tour through the list to solve your appliance problem
Or you describe your problem here,
Thank you,
Dec 07, 2010 | Viking Air Tools & Compressors
Hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
May 30, 2010 | Hilti TE 70 Hammer Drill Performance...
Max roofing nailer
Max nailers are very good quality and parts are not expensive. Parts and parts list at www.toolpartsdirect.com. Check the following to repair not feeding problem.
Check paw in the door should have a light spring action. Feed paw should have a medium spring action. You may have to pull the feed piston back and hold to check feed paw spring action. Feed piston should have heavy spring action. If springs seem ok then remove feed piston and replace two orings. If the feed piston spring is broken replace with correct part. Make sure that the ports that direct air to feed piston are not blocked with bits of rubber or dirt. Sometimes parts of the bumper will break off and spread thru-out the gun. Good Luck and enjoy. (parts not expensive)
Oct 12, 2008 | Air Tools & Compressors
Inserting new drill bit
Assuming that it is this drill:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/7144-04_TYPE_4
You will need a chuck key - hopefully you have that with the drill. It's a little t-shaped bar with a cog on one end. You put it into the holes in the chuck (the part at the end which grps the bit) and turn anti-clockwise to open the jaws. Place a bit in the centre and then turn it clockwise to tighten. Tighten the bit using each of the three holes in the chuck and make sure you remove the chuck key before you use the drill - keep it safe!
Sep 23, 2008 | Drills
Ratchet troubleshoot
Aug 27, 2008 | Campbell Hausfeld 1/2" Ratchet
Inside fan blows but outside unit does not come on - therefore no cool air. What likely is the problem?
This could be
1. No signal from the thermostat
2. A faulty coil on the contactor.
3. A faulty disconnect feeding the condensing unit.
4. corroded connections on the contactor.
5. A broken wire or a wire that has came off a position.
6 A high pressure switch keeping the signal to the contactor off.
Be careful when troubleshooting this there is line voltage and a capacitor in this system.
Jun 30, 2008 | Heating & Cooling
Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS Logo
127 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
