Question about Makita Industrial Quad-Driver Countersink No.6 Model 784834-A
Fluid adding troubleshooting
How do I add fluid in a way that wont harm the tool?
    President:
  • 2,712 Answers
Hydraulic fluid straight from the drum, has a typical cleanliness level of ISO 4406 21/18. A 25 GPM pump operating continuously in hydraulic oil at this cleanliness level will circulate 3,500 pounds of dirt to the hydraulic system's components each year! To add hydraulic oil, and not the dirt, always filter new oil prior to use in a hydraulic system. This can be accomplished by pumping the oil into the hydraulic reservoir through the system's return filter. The easiest way to do this is to install a tee in the return line and attach a quick-connector to the branch of this tee. Attach the other half of the quick-connector to the discharge hose of a drum pump. When hydraulic oil needs to be added to the reservoir, the drum pump is coupled to the return line and the oil is pumped into the reservoir through the return filter. As well as filtering the oil, spills are avoided and the ingress of external contamination is prevented. The benefits of carrying out this simple modification are well worth the minor cost involved.
Posted on Aug 27, 2008
How do you add transmission fluid to a chrys 300 m
You can't. There is a special tool required to do so. You will need to talk to either a transmission shop or take it to a chrysler dealership. Let me rephrase. You can add fluid the same way you can in all automatic transmission (thru the dipstick tube). You will not be able to check the fluid level when you are done adding the fluid.
May 05, 2011 | 2000 Chrysler 300M
Does adding a transmission additive to pontiac grand prix 2006 help with slipping, or harm the system?
If it slips,the ONLY SOLUTION is to rebuild it
I used to own a trans repair business
You NEVER ADD ANYTHING to an automatic trans,
but the correct fluid,period ,never
LubeGard Products, are used for certain issues
by professionals
Dec 21, 2010 | 2006 Pontiac Grand Prix
Wher do I put transmission fluid in my 2000 pontiac montana
THIS IS A SEALED TRANSMISSION AND HAS NO DIPSTICK TUBE,THE DEALER HAS A SPECIAL TOOL FOR CHECKING FLUID LEVEL, THE PLUG FOR ADDING FLUID IS ON THE TOP OF THE HOUSING NEAR WHERE THE LEFT AXLE GOES OUT. DON'T JUIST BLINDLY ADD FLUID, IF U OVERFILL IT U CAN BURN UP THE TRANSMISSION.
Nov 06, 2009 | 2002 Pontiac Montana
Can anyone add brake fluid to the truck? is there
There is nothing special to adding brake fluid. With the hood open on the drivers side on the firewall you should see the master cylinder. The cover is either a small round cap that will just spin off or a rectangular one that will pull off. Use DOT 3 fluid and fill. Make sure no dirt falls in.
Oct 27, 2009 | 1990 Toyota Pickup
Where do I add the transmission fluid? HELP We just put a trans pan on a 2003 Jag SR vin SAJEA03VX31M90957 and we do not know how to add the fluid.
it is like a lincoln LS. same trans. here is procedure. please don't forget to rate. thanks
Fluid Fill Reference NOTE: The left side of case is shown. The fill plug is on the right side of the extension housing.
Item Part Number Description 1 — Fluid fill plug (bench) 2 — Fluid level 3 — Fluid drain plug (large) 4 — Fluid level and fill plug (small) 5 — Fluid level tube
Check
  1. Place a drain pan under the transmission.
  1. NOTE: It will be necessary to hold the drain plug (larger plug) with a wrench when removing the fluid level indicator plug.
    With the transmission in the PARK position and the engine running, use a 3/16 inch Allen key to remove the fluid level indicator plug.
  1. Allow the fluid to drain. Wait approximately one minute. When the fluid comes out as a thin stream or a drip, it is at the correct level.
  1. If no fluid comes out of the hole, fluid will need to be added. Continue with this procedure.
  1. Install the special tool into the pan.
  1. Using the special tool, extract approximately one pint of clean automatic transmission fluid from a suitable container.
  1. Using the special tools, fill the transmission with clean automatic transmission fluid.
  1. Remove the special tool.
  1. Allow fluid to drain. Wait approximately one minute. when fluid comes out as a thin stream or drip, the fluid is at correct level. If no fluid drains from the plug, continue adding clean automatic transmission fluid in 1/2-pint increments until fluid starts to drain from the plug.
  1. Remove the special tool from the pan.
  1. Reinstall the fluid level indicator plug.
Aug 05, 2009 | 2003 Jaguar S-Type
CONVERTIBLE TOP WONT GO UP
Well you certainly have a leak somewhere Trace hoses back Fluid could be leaking into trunk or inside body panels etc
Jul 10, 2009 | 2006 Jaguar XK-Series
Can I add fluid to rear tires w/o hurting rear end.
Adding fluid to the tires should not affect the transmission at all.
May 19, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
My husband made a stupid mistake. He started to add oil to our 2002 530i when he realized he was pouring it into the transmission fluid hole. He thinks about 1/3 of a quart went in before he realized his...
Yes it Will! You need to take it to the Dealership and have them Drain and Flush the Transmission Before it gets Ruined. Oil is a LOT Heavier than Trans Fluid and will harm the Clutches inside.
Jan 05, 2009 | BMW 530 Cars & Trucks
I add 0.5 qourt of engin oil to the transmission will i chang the transmission filter
you have done harm here. Engine oil goes in the engine oil reservoir, you should have added trans fluid and change filter if it is dirty or torn.
Sep 25, 2008 | Pontiac Bonneville Cars & Trucks
Drill how to
Aug 27, 2008 | Bosch HCBG500, 5 Pc Industrial Hammer...
Makita Industrial Quad-Driver Countersink No.6 Model 784834-A Logo
320 people viewed this question
Top Makita Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Makita Home Fencing Expert? Answer questions, earn points and help others
