Question about Black & Decker/DWLT DW2513 15-Piece Rapid Load Drill Driver Set With Case
Hydraulics Question Why do hydraulic systems overheat?
    President:
  • 704 Answers
Another often overlooked situation that causes hydraulic systems to overheat are, obstructions or blockages in the system, dirty or clogged hydro oil filter(s), using a tool that is designed for a closed system or an open system on a pump unit or hydraulic power source or pump of the opposite design (open or closed system operation). Also, check to be sure no restrictor/flow limiters have been installed on the system or tools, or that any reducer "washers" are at any fittings, couplers or other connection points.
Also, all hydraulic oil is hydroscopic, meaning that it will absorb water over time and thus become less effective and contaminated. This is why it is good to change the hydraulic fluid/oil at least once a year to avoid such problems, even if the tool hasn't been used all that much.
Posted on Jul 07, 2009
    President:
  • 2,712 Answers
Heating of hydraulic fluid in operation is caused by inefficiencies. Inefficiencies result in losses of input power, which are converted to heat. A hydraulic system's heat load is equal to the total power lost (PL) through inefficiencies and can be expressed as: PLtotal = PLpump + PLvalves + PLplumbing + PLactuators If the total input power lost to heat is greater than the heat dissipated, the hydraulic system will eventually overheat.
Posted on Aug 27, 2008
My jd 3039r hydraulics. Loader and backhoe buckets lose position when running or shut down. Do I need to bleed hydraulics? If yes, how?
no
hydraulic system self bleed from repeated use
what you have are piston seal worn, cylinder walls damaged allowing bypass of oil or faulty control valve units
Oct 30, 2017 | Garden
I have a 1998 Dodge Dakota 3.9 with a 5 speed. I am having difficulties with the clutch and am trying to figure out if it is the clutch needing replaced or if it is the hydraulics.
Bad hydraulics (leaking/spongy) and worn out clutch have opposite symptoms. If the clutch does NOT ENGAGE - get the vehicle moving - you probably need to replace the clutch and/or pressure plate.
If the clutch does NOT DISENGAGE - you can't get the transmission into gear, or there is difficulty or grinding when trying to shift between gears - your hydraulic system is not moving the clutch release arm far enough to disengage the clutch.
Jun 09, 2017 | 1998 Dodge Dakota
WHAT TYPE FLUID IN HYD SYSTEM
If your hydraulics and trans are one using the same oil then use ATF oil, if your hydraulics is a separate tank then you can use a hydraulic oil, ATF, or a light weight oil
Jan 12, 2016 | Garden
93 ford F800 park brake will not hold
The first thing to check is the amount of linings on the shoes . If less than 50 % replace the linings/ shoes. Next check the adjustment is right up . Park brake operation should never rely on hydraulics for the simple reason that hydraulics leak and the brakes come off. It will probably be spring loaded with the electric over hydraulics holding the brakes off when moving
Feb 19, 2014 | Cars & Trucks
Hydraulics stuck won't let trailer back come down
Bleed the hoses.Too much air in the system and low on hydrolic fluid.
Dec 20, 2012 | Hydraulic Dump Trailer Blueprints
What oil should i put in Fiat 411r hydraulics?
I read someplace the hydraulics use the engine oil. I have the same question. It looks like the hydraulic pump is located at the right hand side of the engine block, forward and is connected to it. Although the previous owner of my tractor used hydraulic fluid.
Apr 10, 2012 | Cars & Trucks
I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Feb 08, 2010 | Parat 1:32 Scale Diecast Replica: 1920...
The hydraulics on a white 2-105 dont work.
check if the pump is working,n if there is oil in the system
Apr 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black & Decker/DWLT DW2513 15-Piece Rapid Load Drill Driver Set With Case Logo
251 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
