Question about Stanley 60 220 20 Piece Screwdriver Set
Troubleshooting can I modify the pressure in my tool? What could be the consequences?
    President:
  • 2,712 Answers
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Posted on Aug 27, 2008
Just wondering what is: P1811 Maximum Adapt And Long Shift
P1811
The transmission pressure is modified by an adaptive modifier which controls the shift execution time. This diagnostic tests the time required to accomplish the shift. If the shift takes longer than 0.65 seconds and the adaptive modifier cannot shorten this time, then a counter increases by one.
If the PCM detects a counter value of 2 during one trip, then DTC P1811 sets. DTC P1811 is a type C DTC
The 1-2, 2-3 or 3-4 shift is longer than 0.65 seconds, twice in one trip.
Ask the customer about possible overloading, exceeding the trailer towing limit, or towing in overdrive.
Ensure that the current PCM calibration is correct for the final drive ratio.
  1. Use the scan tool snapshot mode in order to record the shift times.
  2. Drive the vehicle in D4 in order to obtain a 1-2, 2-3 and 3-4 upshift.
  3. Record the shift times.
Did all the shift times exceed the specified value?
0.65 seconds
Perform the Line Pressure Check Procedure.
Refer to the Line Pressure Check .
Is the line pressure within specifications?
Go to Diagnostic Aids
You may want to take this to the dealer !
Apr 20, 2015 | 2003 Chevrolet Impala
The touch screen does not respond to touch except for one small spot in the upper left corner where it says "job list". Can not log on to copy
Due to the environment, over time conductivity of the touchscreen connection deteriorates because of high temperature or high humidity. Consequently, the area between the conductive cover and glass expands and loses connection. Today, The Touchscreen has been modified and should be replaced when the symptom occurs
Jan 30, 2011 | Konica Minolta bizhub C250 All-In-One...
Ok so my engine is making a ticking sound in the far back what is it?
My guess is that it's a lifter. It's best to talk with a dealership mechanic about the best course of action with your specific vehicle. Usually a engine will last a very long time with a lifter tick. And don't forget to always check for recalls on all the cars you own. Here is a couple I found for your call. In this case it has nothing to do with your ticking problem but for future reference its always a good idea to make sure it's not part of the problem.
Auto Recall Date:MAR 23, 1994 Vehicle Component: POWER TRAIN:MANUAL TRANSMISSION Estimated Vehicles Affected:31295 1992 Subaru Legacy Defect Summary:WHEN THE VEHICLE IS DRIVEN CONTINUOUSLY UNDER EXTREMELY COLD TEMPERATURES (-22 DEGREES F.) AND HIGH HUMIDITY WEATHER CONDITIONS, THE TRANSMISSION BREATHING (AIR) VENT CAN BE BLOCKED DUE TO MOISTURE FREEZING AT THE OIL LEVEL GAUGE. IF THIS OCCURS, PRESSURE INSIDE THE TRANSMISSION CASE WILL INCREASE AND PUSH OUT THE REAR OIL SEAL, CAUSING TRANSMISSION OIL LEAKAGE. THE LACK OF LUBRICATION CAN BURN THE INTERNAL COMPONENTS OF THE TRANSMISSION, CAUSE THE TRANSMISSION TO SEIZE AND THE VEHICLE TO COME TO A SUDDEN STOP. Defect Consequence:SUDDEN STOPS WITHOUT PRIOR WARNING CAN CAUSE VEHICLE OCCUPANTS TO BE THROWN AROUND THE VEHICLE AND CAUSE LOSS OF VEHICLE CONTROL WHICH CAN RESULT IN AN ACCIDENT. Remedy:DEALERS WILL MODIFY THE OIL GAUGE PIPE AND MODIFY THE OIL LEVEL GAUGE (DIPSTICK) OR REPLACE IT, DEPENDING ON THE TYPE OF DIPSTICK IN THE VEHICLE. Notes:SUBARU OF AMERICA, INC. Auto Recall Date:APR 01, 1992 Vehicle Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY Estimated Vehicles Affected:9500 1992 Subaru Legacy Defect Summary:A MISALIGNMENT OF THE REAR SEAT CUSHION LATCHING BRACKET REINFORCEMENT PLATE TO THE FLOOR REQUIRED A MACHINE TAP TO CLEAR THE OPENING FOR A MOUNTING BOLT. THE TOP OF THE FUEL TANK MAY HAVE BEEN PUNCTURED WHEN THE TAP WAS USED. Defect Consequence:THE PUNCTURE IN THE TOP OF THE FUEL TANK COULD CAUSE FUELTO LEAK, WHICH COULD RESULT IN A VEHICLE FIRE WHEN LEAKS OCCUR NEAR A SOURCE OFIGNITION. Remedy:INSPECT THE FUEL TANKS; REPLACE THEM IF THEY ARE PUNCTURED. Notes:SUBARU OF AMERICA, INC.
Jun 25, 2010 | 1992 Subaru Legacy
I have a 79 ford f-150 with a 351w modified engine. when i first start the engine it has approx. 65 psi oil pressure. as the engine warms up the pressure slowly drops off to around 12 psi.the oil is clear...
First off its not a 351W modified. you are confusing two different blocks. its either a 351 windsor or a 351m (modified) and if it is the modified its not that bad. these engines are notorious for having low oil pressure. at idle they can be anywhere between 10 and 40. as long as you gain 10 psi per 1000 rpm its fine. and a pump doesnt drop off as it gets warm. it either works or it doesnt, oil pressure dropping off is a bottom end bearing problem
May 20, 2010 | 1981 Ford F 150
P 1750 cod come up. has shifting problem.
DTC P1750: Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve Assemblies A and B, or Problem in Hydraulic Control System
NOTE:
• Record all freeze data and review General Troubleshooting Information before you troubleshoot.
• Keep these replacement solenoid valves on hand:
• A/T clutch pressure control solenoid valves A and B
1. Check whether the OBD II scan tool indicates another code. Does the OBD II scan tool indicate another code? YES - Perform the troubleshooting flowchart for the indicated code(s). Recheck for code P1750 after troubleshooting. NO - Go to step 2.
2. Turn the ignition switch OFF.
3. Replace the A/T clutch pressure control solenoid valves A and B.
4. Reset the PCM memory with the PGM Tester or by removing the BACK UP fuse in the passenger's underdash fuse/relay box for more than 10 seconds .
5. Drive the vehicle for several minutes in 1st, 2nd, 3rd, 4th, and 5th gears in the position.
6. Recheck for code P1750. Does the OBD II scan tool indicate code P1750? YES - Replace the transmission. NO - The problem has been corrected
Jul 08, 2009 | Acura TL Cars & Trucks
Drill Question
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Fron suspension camber
You can install the original shocks by contacting local service center or you order them online but make sure to mention right model and make because differ from each other and get it install.
Jun 10, 2008 | 2000 Audi A4
Stanley 60 220 20 Piece Screwdriver Set Logo
94 people viewed this question
Top Stanley Hand Tools Experts
Jim Thurston
Ivan
Ivan
Level 1 Expert
Don Numinen
Don Numinen
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
