Question about Casio Cassiopeia E-105 Pocket PC
External batteries I don't know if my battery is old, but using the backlight on full and playing movies from the CF card, the battery in my E-105 doesn't even make it a whole hour. Anybody know how long a new battery should last under these conditions? So here's what I do. I soldered a 4xAA battery holder to a few feet of wire with a coaxial DC plug on the end that fits the Cassiopeia. I fill it with NiMH AA cells (1.8Ah), since I have a lot and they are easy to recharge. I ran it this way for 1.5 hours on a plane and they still weren't depleted. I haven't had a chance to run it all the way down. Since the unit considers itself to be on AC power, the battery saving features don't activate and you can watch the video uninterrupted. 4 AA cells in the holder fits pretty easily in a coat pocket, as do an extra set of cells. This way I can use the unit as long as I need to on airplanes, airports and subways. Plus, when the AA's are drained, I still have a full internal battery to use. I was going to buy a second Casio battery, but they are at least $35 and require you to remove the unit from it's case, open the cover and risk running down the backup battery. This setup costs <$10 (it was free for me since I had all the parts sitting around) and simply plugs in. It will also charge the internal battery off the AA cells. I was also considering setting up a 6V 5A-h gell cell with a 5V regulator (should be good for 4-5x the run-time of the internal battery), but the gel cell requires a specific charger and is relatively heavy. The NiMH batteries give about 5.4V. Alkalines give 6. I'm not sure if this is recommeded, since the Casio power supply is rated at 5V. I did try it and it everything worked fine. I haven't actually tested the output voltage of the Casio adapter, but it is probably >5V at low loads and only drops as low as 5V when you are running and charging at the same time.
    Master:
  • 551 Answers
Sounds to me like you have a winning plan of attack. I did the same thing a couple years back, bought one of those 4XAA battery holders with a little slide switch and put a jack on the end of the wire...worked fine. Then I bought a 6V 1500 mAh rechargeable battery from Radio Shack that was made for r/c cars and such. It worked great too. Never had problem one with either setup.
Posted on Sep 06, 2005
How to care my hp dv5 battery? buy the hp dv5 battery from http://www.batteryfast.com/hp/pavilion-dv5.htm
For long life battery:
-Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
-Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
-Adjust your screen brightness - Dimming your display saves battery power.
-Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
-Decrease or mute the Laptop Speaker Volume.
-Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Mar 19, 2012 | Computers & Internet
Screen freeze
than your computer cannot supprt full screen movies..
Sep 15, 2009 | Compaq Presario 5000 PC Desktop
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
My Fujifilm S9600 draining batts rapidly...
Hi !! With your comments I was thinking on al old problem that I have with a Fuji S7000 using a CF card, it drains the battery very fast, but the problem was the CF card, not the camera, I switch to a XD memory card and problem solved, Are you using a CF memory card?
Apr 13, 2009 | Fuji Rod Repair Kit
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error code 22
ERR 22: CF DRIVER
DESCRIPTION: This error occurs when image data cannot be written to the CF card. This error can occur when the CF card is not fully seated in the camera or if the D30 does not detect a card-ready signal within a specified time limit or when the CF card is not usable because it has been corrupted or physically damaged. It can also occur when the camera's battery level is insufficient to completely write the file to the CF card. REMEDIAL MEASURE: Use the DC Coupler or recharge the battery first. If the error continues to occur with sufficient power available to the camera, check that the CF card is properly inserted. If that's not the problem, then try replacing the CF card. If that does not solve the problem, have the EOS D30 and one of the CF cards that is causing the problem examined by a qualified service technician.
Got this from here: Digital Outback Photo
Feb 09, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
No take picture!
Hi John,
Try using the AC Adapter as your battery.
atdlee@netzero.com
Jan 06, 2008 | Canon EOS-5D Digital Camera
CF FULL
I just had exactly the same problem with my 20D. I removed and reinserted the battery and it fixed the problem.
Dave
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
GCMK-M1X
Oct 21, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Casio Cassiopeia E-105 Pocket PC Logo
111 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
