Question about Bosch PC11PCM Power Change BiMetal Master Hole Saw Kit
Drill problem Why do hydraulic systems overheat?
    Problem Solver:
  • 5 Answers
Heating of hydraulic fluid in operation is caused by inefficiencies. Inefficiencies result in losses of input power, which are converted to heat. A hydraulic system's heat load is equal to the total power lost (PL) through inefficiencies and can be expressed as: PLtotal = PLpump + PLvalves + PLplumbing + PLactuators If the total input power lost to heat is greater than the heat dissipated, the hydraulic system will eventually overheat.
Posted on Aug 27, 2008
Simplicity Champion Hydraulic Oil overheating
I would have to say you will continue to have this problem until you resolve it. If it continues to overheat with an oil cooler installed, I would check to see if the pump is operating at the proper pressure.
Jun 05, 2013 | Garden
The hydraulic hose connector is broken. Can't find a manual or parts list.
You can get that hose made at a place like NAPA . The hose is a couple of dollars a foot and the fittings are about 10 a peice Bring the old one with you it takes 10 munites to make
Mar 14, 2011 | Torin Big Red Hydraulic Shop Press with...
HAve clausing 1650. Large Drill bits overheat and
You should use a honing type of oil when drilling with large bits. There is a tremendous amount of friction and the oil keeps the bits cooler when cutting.
Nov 15, 2009 | Drills
Hydraulic jack will not lower
hs it been overfilled? I sugest removin all the oil. lowering the jack, then re-filling withoil with the jack in the closed possition.
Feb 12, 2009 | RTO 20 Ton Air / Hydraulic Bottle Jack
Hydraulics Question
Aug 27, 2008 | Black & Decker/DWLT DW2513 15-Piece Rapid...
Puller Question
Six routines must be followed in order to minimize the chances of your hydraulic equipment suffering costly, premature component failures and unscheduled downtime: * Maintain fluid cleanliness; * Maintain fluid temperature and viscosity within optimum limits; * Maintain hydraulic system settings to manufacturers' specifications; * Schedule component change-outs before they fail; * Follow correct commissioning procedures; and * Conduct failure analysis.
Aug 27, 2008 | Black & Decker/DWLT DW2518 30-Piece Rapid...
Drill how to
Hydraulic fluid straight from the drum, has a typical cleanliness level of ISO 4406 21/18. A 25 GPM pump operating continuously in hydraulic oil at this cleanliness level will circulate 3,500 pounds of dirt to the hydraulic system's components each year! To add hydraulic oil, and not the dirt, always filter new oil prior to use in a hydraulic system. This can be accomplished by pumping the oil into the hydraulic reservoir through the system's return filter. The easiest way to do this is to install a tee in the return line and attach a quick-connector to the branch of this tee. Attach the other half of the quick-connector to the discharge hose of a drum pump. When hydraulic oil needs to be added to the reservoir, the drum pump is coupled to the return line and the oil is pumped into the reservoir through the return filter. As well as filtering the oil, spills are avoided and the ingress of external contamination is prevented. The benefits of carrying out this simple modification are well worth the minor cost involved.
Aug 27, 2008 | Bosch HCBG500, 5 Pc Industrial Hammer...
Drill support
Hydraulic fluid temperatures above 180°F (82°C) damage most seal compounds and accelerate degradation of the oil. While the operation of any hydraulic system at temperatures above 180°F should be avoided, fluid temperature is too high when viscosity falls below the optimum value for the hydraulic system's components. This can occur well below 180°F, depending on the fluid's viscosity grade.
Aug 27, 2008 | Bosch 10.8V Pocket Driver
Drill Question
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drill Troubleshooting
Aug 27, 2008 | Dewalt 29 Pieces. Drill Bit Set, Pilot...
Bosch PC11PCM Power Change BiMetal Master Hole Saw Kit Logo
241 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
