Question about Bosch 10.8V Pocket Driver
Drill support Hydraulic fluid temperature - how hot is 'too hot'?
    Problem Solver:
  • 4 Answers
Hydraulic fluid temperatures above 180°F (82°C) damage most seal compounds and accelerate degradation of the oil. While the operation of any hydraulic system at temperatures above 180°F should be avoided, fluid temperature is too high when viscosity falls below the optimum value for the hydraulic system's components. This can occur well below 180°F, depending on the fluid's viscosity grade.
Posted on Aug 27, 2008
Where is the power steering temperature sensor on 1993 Toyota Camry v6
On some Camrys the radiator fan is run by hydraulic pressure from the power steering pump. I think the sensor you mention is the engine coolant temperature sensor, which is in the circuit which operates the fan when the engine becomes hot. If this fails the engine will overheat, yes. The fan does not cool the hydraulic fluid from the pump.
If your power steering fluid gets low the same thing can happen, but you would notice immediately as the steering would become intermittently harder.
Jan 02, 2012 | 1993 Toyota Camry V6
Hydraulics Question
Heating of hydraulic fluid in operation is caused by inefficiencies. Inefficiencies result in losses of input power, which are converted to heat. A hydraulic system's heat load is equal to the total power lost (PL) through inefficiencies and can be expressed as: PLtotal = PLpump + PLvalves + PLplumbing + PLactuators If the total input power lost to heat is greater than the heat dissipated, the hydraulic system will eventually overheat.
Aug 27, 2008 | Black & Decker/DWLT DW2513 15-Piece Rapid...
Puller Question
Six routines must be followed in order to minimize the chances of your hydraulic equipment suffering costly, premature component failures and unscheduled downtime: * Maintain fluid cleanliness; * Maintain fluid temperature and viscosity within optimum limits; * Maintain hydraulic system settings to manufacturers' specifications; * Schedule component change-outs before they fail; * Follow correct commissioning procedures; and * Conduct failure analysis.
Aug 27, 2008 | Black & Decker/DWLT DW2518 30-Piece Rapid...
Impact wrench problems
Aug 27, 2008 | Campbell Hausfeld SNUBNOSE 1" IMPACT...
Drill how to
Hydraulic fluid straight from the drum, has a typical cleanliness level of ISO 4406 21/18. A 25 GPM pump operating continuously in hydraulic oil at this cleanliness level will circulate 3,500 pounds of dirt to the hydraulic system's components each year! To add hydraulic oil, and not the dirt, always filter new oil prior to use in a hydraulic system. This can be accomplished by pumping the oil into the hydraulic reservoir through the system's return filter. The easiest way to do this is to install a tee in the return line and attach a quick-connector to the branch of this tee. Attach the other half of the quick-connector to the discharge hose of a drum pump. When hydraulic oil needs to be added to the reservoir, the drum pump is coupled to the return line and the oil is pumped into the reservoir through the return filter. As well as filtering the oil, spills are avoided and the ingress of external contamination is prevented. The benefits of carrying out this simple modification are well worth the minor cost involved.
Aug 27, 2008 | Bosch HCBG500, 5 Pc Industrial Hammer...
Drill problem
Aug 27, 2008 | Bosch PC11PCM Power Change BiMetal Master...
Drill Question
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drill Troubleshooting
Aug 27, 2008 | Dewalt 29 Pieces. Drill Bit Set, Pilot...
HYUNDAI TRANSMISSION
1. Drive the vehicle until the fluid temperature reaches normal operating the usual temperature [80-90°C (176-194°F)]. 2. Place the vehicle on a level floor. 3. Move the selector lever sequentially to every position. This will fill the torque converter and hydraulic system with fluid, then place lever in "N" (Neutral) position. 4. Before removing the dipstick, wipe all contaminate from area around the dipstick. Then take out the dipstick and check the condition of the fluid. The transaxle should be overhauled under the following conditions. a. If there is a "burning" odor. b. If the fluid color has become noticeably blacker. c. If there is a noticeably excessive amount of metal particles in the fluid. 5. Check to see if the fluid level is in the "HOT" range on dipstick. If fluid level is low, add automatic transaxle fluid until the level reaches the "HOT" range. Transaxle fluid: GENUINE HYUNDAI ATF SP-II, DIAMOND ATF SP-II or AUTRAN MMSP-II. Low fluid level can cause a variety of abnormal conditions because it allows the pump to take in air along with fluid. Air trapped in the hydraulic system forms bubbles which are compressable. Therefore, pressures will be erratic, causing delayed shifting, slipping clutch and brakes, etc. Improper filling can also raise fluid level too high. When the transaxle has too much fluid, gears churn up foam and cause the same conditions which occur with low fluid level, resulting in accelerated deterioration of automatic transaxle fluid. In either case, air bubbles can cause overheating, and fluid oxidation, which can interfere with normal valve, clutch, and servo operation. Foaming can also result in fluid escaping from the transaxle vent where it may be mistaken for a leak. 6. Be sure to examine the fluid on the dipstick closely.0f3ac6e.gif
Jun 30, 2008 | Hyundai Motor 1999 Tiburon
Bosch 10.8V Pocket Driver Logo
162 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
