Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Drill Question can I modify the pressure in my tool? What could be the consequences?
    Problem Solver:
  • 4 Answers
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Posted on Aug 27, 2008
How do i close the chuck on a dewalt dcd950
The DCD950 was DeWalt's worst chuck design. This chuck has no chuck screw, they loaded the spindle with locktite and put them on. Consequently, the chucks are nearly impossible to remove. DeWalt made a tool for this purpose, but it costs almost $90 - the only alternative was to replace the gearcase assy but they just made it obsolete, no longer available.
There is a conversion kit but the problem remains, you still need to be able to remove the old chuck.
We have used a metal cutting saw to cut the chuck off - about the only thing that works Conversion Kit N422782 for DeWALT Power Tool eReplacement Parts
Sep 25, 2014 | Dewalt Dcd950 Hammer Drill Uses Dc9096 Or...
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My suzuki gsxr 1000 k3 will start then cut out six times before it runs properly on its own in the cold
Instructions
  1. Take Down
    • 1 Park the motorcycle on the kickstand or center stand and allow the exhaust pipes to cool completely.
    • 2 Refer to your Suzuki service manual and organize the metric tools needed to remove the baffle. On newer models, it may be necessary to remove the tailpipe section to modify the baffle. On older models, you may be directed to remove a bolt that secures the baffle in the tailpipe.
    • Follow the procedure given in the manual and remove the tailpipe section or slide-in baffle using the appropriate tools. Save any brackets or bolts. Place the tailpipe or baffle on a workbench.
    Tailpipe Baffles
    • 4 Hold one end the tailpipe up to a light and look inside the other end. Depending on the baffle, you may see very little light or none at all. Modifying the baffle is a matter of opening up areas in the baffle.
    • 5 Chuck a 1/4-inch drill bit in an electric drill. Use a bit extension if necessary to reach deep into the tailpipe with the drill bit.
    • 6 Place the tailpipe on a workbench. Use a towel or rags to prevent scratching the finish. Insert the tip of the drill bit into the tailpipe and drill a 1/4-inch hole in the baffle.
    • 7 Hold the tailpipe up to the light again. Determine the number of additional holes you want based on the purpose of the modification. Drill additional holes in the baffle if needed.
    • 8 Stand the tailpipe on end and tap it on the workbench to clear the debris from drilling out of the baffle. Make sure all debris is cleared out before reinstalling the tailpipe on the motorcycle.
    Slide-In Baffles
    • 9 Secure the outer end of the baffle in a bench vise with the baffle extending to one side. The outer end has the threaded hole where the bolt was removed to take the baffle out of the exhaust pipe.
    • 10 Measure the length of the baffle and divide it by four. You modify a slide-in baffle by cutting off a one-quarter section at a time using a hacksaw. Mark the baffle at the one-quarter point and cut the first section off the end.
    • 11 Reinstall the baffle in the exhaust pipe using the saved bolt and the metric tool.
      Start the motorcycle and determine if the modification produced the desired result.
    • 12 Allow the exhaust pipe to cool completely before removing the baffle for further modification. Most likely, cutting one or two quarter sections will give you the result you want. Avoid cutting too much off the baffle, or it will be useless.
Jan 17, 2013 | Motorcycles
Are the outer forks the same on a gsx 1400 k4 as. K5 ?
Instructions
  1. Take Down
    • 3 Follow the procedure given in the manual and remove the tailpipe section or slide-in baffle using the appropriate tools. Save any brackets or bolts. Place the tailpipe or baffle on a workbench.
    Tailpipe Baffles
    Slide-In Baffles
Jan 15, 2013 | Suzuki GSX 1400 Motorcycles
Dirver won't impact working like drill...
Depends how old the tool is and how hardly/frequently it was used. It has mechanical impact mechanism, not a electro-pneumatic. And mechanical one can be worn off after certain period of use. If your drill is new, issue can be either "wrong tool" - then return it to the shop, or you have not turned hammering on - check user manual. Impact effect will occur only if you put a pressure on the drill bit. Juraj
Oct 11, 2010 | Ryobi Drills
Dewalt 28v drill/driver making screeching noise
No, this is not normal. Take it back to your retailer and let them know about the problem.
I have a few tools that will get a little noisy and it is cold out - as in lower than 15 degrees - but it goes away as the tool warms up.
Your problem sounds like clearance issues within the drill, and just dealing with the noise could be damaging the tool further.
Oct 12, 2009 | Dewalt Drills
'Choice or Pass Along Items'
you might mean modifiers, that's what i'd usually set up. there are choice items too though but i think modifiers are most useful for restaurants.
Modifiers: http://faq.pcamerica.com/file-lockers/pdf-locker/Creating_modifiers.pdf
Mar 02, 2009 | Pc America Restaurant Pro Express
Air drill tips
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Troubleshooting
Aug 27, 2008 | Stanley 60 220 20 Piece Screwdriver Set
Finger Switch
Call1-800-423-3598,give them your model number so they can send a replacment trigger assy.
Dec 08, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
129 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
