Question about AMANA TOOL 3400 DOUBLE EDGE LAMINATE TRIMMER
Laminate specifications How much motor power does a laminate trimmer usually have?
    Problem Solver:
  • 4 Answers
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Posted on Aug 27, 2008
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
Will a Porter Cable 7312 offset base laminate trimmer also work on Model 7301 HD POWER UNIT
I think it's meant to fit the 7310 trimmer, as the series numbers are in sequence. But when I look at the parts list for the 7301 & 7310, they seem to have the same motor housing part number, which indicates they are more or less the same size, no?
Check at the following website, http://www.dewaltservicenet.com/SearchResults.aspx?q=laminate%20trimmer
They also provide the means to ask them a question, if you're not sure you want to risk returning an order, in which case you want to link:
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/ask.php?p_sid=tZeaxJtj&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNzM4LDE3MzgmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x
I hope this info allows you to sort it out.
Sep 01, 2008 | Porter Cable Porter-Cable 7311 Offset...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Laminate Support
# Use a straight base. # Make sure the bit height is correct. To adjust the height, loosen the base and turn the wheel on the side of the tool. When you've got the right height, tighten down the base. # Rest the tool over the top of the work piece, then turn it on. # Push the tool forward to trim around the edge of the work.
Aug 27, 2008 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate Trimmer troubleshoot
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Aug 27, 2008 | Ridgid 120V 6.0Amp Laminate Trimmer
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
AMANA TOOL 3400 DOUBLE EDGE LAMINATE TRIMMER Logo
153 people viewed this question
Top Amana Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Amana Tool and Hardware - Other Expert? Answer questions, earn points and help others
