Question about Freud FT750T Laminate Trimmer
Laminate Trimmers question
Dremel vs. laminate trimmer vs. router: which jobs for each?
    Novelist:
    Champion:
  • 277 Answers
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Posted on Aug 27, 2008
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
SUM 5/16 INCH 7/8 INCH
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Nov 17, 2009 | Bosch 85414M 7/8 Inch Diameter 5/16 Inch...
Need to find new base screws sstripped on tightening of old base. Where can I buy replasement.
Go to FREUDTOOLS.com buy from them I have several times good folks 1 800 334 4107. don't try a substitute until you talk with them.
good luck!
Oct 04, 2009 | Freud FT1000EK Plunge Router/Laminate...
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
Collet chuck for Ryobi router R150 was broken
Ryobi - Sydney phoned and they had the part available so proceeded, thanks
Allan Japp
Dec 16, 2008 | Ryobi Laminate Trimmer Kit
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmer troubleshoot
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Aug 27, 2008 | Ridgid 120V 6.0Amp Laminate Trimmer
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Freud FT750T Laminate Trimmer Logo
288 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
