Question about Porter Cable Porter-Cable 309 3.8 Amp Laminate Trimmer
Laminate Support How do I trim lamiate?
    Problem Solver:
  • 4 Answers
# Use a straight base. # Make sure the bit height is correct. To adjust the height, loosen the base and turn the wheel on the side of the tool. When you've got the right height, tighten down the base. # Rest the tool over the top of the work piece, then turn it on. # Push the tool forward to trim around the edge of the work.
Posted on Aug 27, 2008
My room is 13 x 12 how many square feet do I need?
13 x 12 = 156 square feet. However, they recommend getting 10% more to allow for staggering seams, trims cuts, and possible defective boards, so you should get at least 170 square feet.
Oct 10, 2015 | Pergo Accolade Castlewood Maple Laminate...
Trimming endcap on Formica countertop
is it already in place? you can trim it with a skill saw, make sure the blade is sharp and sand down the corners after to make them more round
Jan 28, 2013 | Building Materials
Where can I find a owners manual for buffalo tools trimbx trim router
Go to the Harbor Freight web site and the the manual for their trim router:
http://www.harborfreight.com/1-4-quarter-inch-trim-router-44914.html
Its the same router.
I am looking for place to get replacement parts, I have 2 of them, both have broken router base.
Sep 01, 2010 | BIT Oldham Saw Company 22 Bevel Laminate...
Makita trim router - Base lock nut keeps breaking
You may have cuttings building up in the slide, throwing it out of alignment and causing offset tension.....
Feb 02, 2010 | Makita Tools & Hardware - Others
SUM 5/16 INCH 7/8 INCH
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Nov 17, 2009 | Bosch 85414M 7/8 Inch Diameter 5/16 Inch...
Brother P-touch 1180 tape cartridge jammed
Man, that tape's a real b!%^ch. I just spent an hour figuring it out, so here ya go... In the center is a (larger that the rest) gray wheel, this is the "toner" take up reel. On the tape that's come out of the cassette, seperate the three layers, and start "reeling in" just the toner. (The laminate and label that have come out are just lost, no real hope for them) When you get close to the end of the toner, help it feed straight back in, and it will go all the way back in. You may have to hold on to the laminate and label so it doesn't try to follow the toner. once that done, it should look like the original cartridge, trim off the excess and you should be good to go.
Brian
Nov 13, 2009 | Brother P-Touch 1180 Label Printer
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Laminate Trimmer troubleshoot
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Aug 27, 2008 | Ridgid 120V 6.0Amp Laminate Trimmer
Porter Cable Porter-Cable 309 3.8 Amp Laminate Trimmer Logo
214 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
