Question about Ridgid 120V 6.0Amp Laminate Trimmer
Laminate Trimmer troubleshoot
What kind of different bases can I use with this tool?
  • 30 Answers
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Posted on Aug 27, 2008
I have a 7301 power unit, 7309 trimmer base, 7311 offset trimmer base and the 7318 tilt trimmer base. The problem I am experiencing is with the power unit. The shaft spins but once I use the lock pin it...
first things first, the lock pin has a spring that is supposed to push it away from the shaft after using, if it is not releasing there could be a burr on the shaft/pin or the spring might be missing. the electrical smell can be from the field or armature and the freezing up might be a bearing which can lead to that smell. I would suggest going to "dewaltservicenet.com" and you can download the owners manual/breakdown for this tool. I think that I saw list price around 63.00 for the trimmer so I would not put a lot of money in the repair. They are not that hard to take apart so let me know if you need more assistance and I will try and help
Apr 22, 2011 | Porter Cable Porter-Cable 7301 5.6 Amp...
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
Need to find new base screws sstripped on tightening of old base. Where can I buy replasement.
Go to FREUDTOOLS.com buy from them I have several times good folks 1 800 334 4107. don't try a substitute until you talk with them.
good luck!
Oct 04, 2009 | Freud FT1000EK Plunge Router/Laminate...
Is there a .pdf manual available for the Porter Cable 7311 offset base?
yes go to Dewaltservicenet.com and type in your model number and it will direct you to a manual it is 25 pages long. If I have helped you would you please rate this response accordingly and thank you.
Sep 17, 2009 | Porter Cable Porter-Cable 7311 Offset...
Will a Porter Cable 7312 offset base laminate trimmer also work on Model 7301 HD POWER UNIT
I think it's meant to fit the 7310 trimmer, as the series numbers are in sequence. But when I look at the parts list for the 7301 & 7310, they seem to have the same motor housing part number, which indicates they are more or less the same size, no?
Check at the following website, http://www.dewaltservicenet.com/SearchResults.aspx?q=laminate%20trimmer
They also provide the means to ask them a question, if you're not sure you want to risk returning an order, in which case you want to link:
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/ask.php?p_sid=tZeaxJtj&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNzM4LDE3MzgmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x
I hope this info allows you to sort it out.
Sep 01, 2008 | Porter Cable Porter-Cable 7311 Offset...
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Laminate Support
# Use a straight base. # Make sure the bit height is correct. To adjust the height, loosen the base and turn the wheel on the side of the tool. When you've got the right height, tighten down the base. # Rest the tool over the top of the work piece, then turn it on. # Push the tool forward to trim around the edge of the work.
Aug 27, 2008 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Ridgid 120V 6.0Amp Laminate Trimmer Logo
226 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
R Daniel Wolfe
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
