Question about Porter Cable Porter-Cable 309 Factory Reconditioned Laminate Trimmer
Laminate Trimmers Troubleshooting
How do I change the bits of my laminate trimmer?
  • Anonymous Mar 14, 2014
    my depth on laminate trimmer keeps on adusting while in use
  • Anonymous Mar 19, 2014
    the laminate trimmers
  • 291 Answers
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Posted on Aug 27, 2008
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
Using a Royobi ERT241200 plunge router to make a channel in Rafiata pine. After some 3 m of succesful cutting, toolf drops down, thus making a deeper cut. Second occurence,and I am no expert. Can not see...
could be a couple of things
1. too deep a cut could pull too hard on the bit and make it lower
2. bit not all the way in the chuck. put bit in as deep as possible, then pull out about 1/16 inch, then titen
hope this helps
Feb 08, 2010 | Ryobi Laminate Trimmer Kit
SUM 5/16 INCH 7/8 INCH
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Nov 17, 2009 | Bosch 85414M 7/8 Inch Diameter 5/16 Inch...
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Laminate Support
# Use a straight base. # Make sure the bit height is correct. To adjust the height, loosen the base and turn the wheel on the side of the tool. When you've got the right height, tighten down the base. # Rest the tool over the top of the work piece, then turn it on. # Push the tool forward to trim around the edge of the work.
Aug 27, 2008 | Porter Cable Porter-Cable 309 3.8 Amp...
Laminate Trimmer troubleshoot
There are several different bases you can use with this tool. One example swivels so you can trim edges at a variety of different angles. An offsetting base allows you to get into tight corners because the bit is located at the edge of the base, rather than in the center. When working with laminate, this particular base is great for creating a backsplash. You can cut around the edges of a circle with a roundover bit.
Aug 27, 2008 | Ridgid 120V 6.0Amp Laminate Trimmer
Porter Cable Porter-Cable 309 Factory Reconditioned Laminate Trimmer Logo
206 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
