Question about Wheeler Rex 77024 2-3/4" Single Tooth Hole Cutter
Glue gun support
How do you get dried-out glue (from a hot glue gun) out of carpet?
    Problem Solver:
  • 5 Answers
Put a towel over the glue and iron over the towl. the glue will melt and the towel will soak it up. That works for other things like crayons also.
Posted on Aug 27, 2008
Try using denatured alcohol from your local hdwe store along with a rag, comb, and even a toothpick . A test area would be my first idea; color fastness and while there is not much odor it may affect some people with allergies and respiratory problems. It will take some time but be careful not to saturate the carpet itself just the immediate area; the alcohol may breakdown adhesives bonding the carpet fibers to the backing or seaming tape on the underside.
Posted on Jan 09, 2009
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
Bought a glue gun to re cover my lamp. Unfortunatley there was no Instructions
Pretty basic to use. Insert glue stick from the rear, push it as far as it will go without forcing it, if there is room put another one behind it. turn on gun and wait til it gets hot. stand it on something that will not get damaged from the glue, a piece of cardboard for example, you should see glue start to drip through the tip. now press trigger (gently at first until glue is really hot) and glue will flow, the longer the gun is on the glue will be easier to get flowing. release trigger and glue will stop, (although a little will still come out) When there is room always place a glue stick behind one already in to help the continuous flow of glue. That's pretty much it really.
Jan 17, 2014 | Master Appliance Crafts & Hobbies
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
What is a spray nozzle for my hot glue gun?
A spray nozzle is an optional accessory that may be a useful addition to your spray gun on some projects. Compressed air is used to force a controlled amount of glue out through a specially designed nozzle which sprays it, as opposed to globbing it out of the original nozzle. This is useful when you want to spread a thinner layer of adhesive, but due to its thinness it will dry quicker- usually within a few seconds.
Feb 26, 2013 | Crafts & Hobbies
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
How to heat gun
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Aug 27, 2008 | B O X Packaging Two Temperature Heat Gun
Wheeler Rex 77024 2-3/4" Single Tooth Hole Cutter Logo
348 people viewed this question
Top Wheeler Rex Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Wheeler Rex Craft and Hobby Expert? Answer questions, earn points and help others
