Question about 3M 5/8 x 8 - Low-Melt Adhesive Clear
Glue Gun Troubleshooting
How Should i Use Sealing Wax with a Glue Gun?
    Problem Solver:
  • 5 Answers
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
Posted on Aug 27, 2008
How to use wire stand on glue gun
the wire stand is there to stop the glue from melting and dripping out the end when you aren't using it. simply fold the wire stand out so that the gun can rest at a 45 degree angle. i would still advise you to set the gun on the wire stand on a paper towel or something, because it may still drip a little.
Feb 16, 2013 | FPC Corporation Trigger fed glue gun
LEAF BLOWER GAS TANK LEAK
Get a hot glue gun and seal the plastic tank. I know it worked for over a year for me and still holding when I moved and sold it. I no longer needed it as I was moving into an apartment.
Dec 28, 2011 | Homelite Garden
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Master mechanic glue gun 207 stopped working
Try cleaning the glue stick slot out with acetone (nail polish remover) and a paper towel, or cue tips if you have to get into a small area. that should help to break down any dried glue that may be blocking a new stick from feeding in, or may be blocking the heating element
May 14, 2010 | Crafts & Hobbies
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Mar 25, 2010 | Crafts & Hobbies
Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
3M 5/8 x 8 -  Low-Melt Adhesive Clear Logo
344 people viewed this question
Top 3M Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a 3M Craft and Hobby Expert? Answer questions, earn points and help others
