Question about SK 83562A 12 - Piece Expert2 Screwdriver Set
Puller support How do I know when the Tempreture of the Hydraulic fluid is to high?
    President:
  • 2,712 Answers
Usually you don't want to go above 180°F (82°C)
Posted on Aug 27, 2008
What kind of hydraulic fluid does my pump for the top need in my convertible 2001 saab 93 2.0l turbo just want to know that thanks
This information will be available from a dealer service centre but in the absence of information from them any hydraulic oil should be ok to use . Try to get the correct oil first but oil used in the power steering would be ok as it is a high pressure ,high temperature oil. If it is too thin then there are specific hydraulic oils that could be used. and obtainable from any oil distribution centre.
May 03, 2014 | 2008 Saab 9-3
Hydraulic temp. of my excavator is high after 30 mins. of operation only? What is the posible cause of this problem? Tnx
If you haven't done so already I would drain all hydraulic fluid after it is warmed up a little. Change any filters and refill with industrial grade fluid. I have had similar problem with my old backhoe when I used cheap fluid and filters. Hope this helps you. Thank you
Mar 30, 2011 | Heating & Cooling
Frost free freezer frosting up
check for the tempreture adjustment knob in the refrigerator section as it might accidently have been turn to extreme high ...setting the refrigerator tempreture to very low can cause this problem in the frezer section try turning the knob to medium or tempreture according to the outside tempreture....
Jan 21, 2011 | Kenmore Refrigerators
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
RED HIGH TEMPRETURE LIGHT IS ON.WHAT IS THE USUAL
if the temperature rises above 30 degrees then this is to let you know that there is a problem.
it could be one of these problems:
dirty condender
condenser fan not running (if available)
freezer fan stop working
compressor valves bad
lost of freon (under charge)
defrost heaters not working
bi-metal t'stat not working
timer bad
if you need more help let me know
Mar 27, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Troubleshooting
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Aug 27, 2008 | Stanley 60 220 20 Piece Screwdriver Set
Puller Question
Six routines must be followed in order to minimize the chances of your hydraulic equipment suffering costly, premature component failures and unscheduled downtime: * Maintain fluid cleanliness; * Maintain fluid temperature and viscosity within optimum limits; * Maintain hydraulic system settings to manufacturers' specifications; * Schedule component change-outs before they fail; * Follow correct commissioning procedures; and * Conduct failure analysis.
Aug 27, 2008 | Black & Decker/DWLT DW2518 30-Piece Rapid...
Troubleshooting
Aug 27, 2008 | kawasaki Impact Wrench Kit 7 Amp, 1/2"...
Drill support
Hydraulic fluid temperatures above 180°F (82°C) damage most seal compounds and accelerate degradation of the oil. While the operation of any hydraulic system at temperatures above 180°F should be avoided, fluid temperature is too high when viscosity falls below the optimum value for the hydraulic system's components. This can occur well below 180°F, depending on the fluid's viscosity grade.
Aug 27, 2008 | Bosch 10.8V Pocket Driver
Drill Question
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
SK 83562A 12 - Piece Expert2 Screwdriver Set Logo
59 people viewed this question
Top SK Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a SK Hand Tool Expert? Answer questions, earn points and help others
