Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Recording problem My Camcorder Powers Up, But Will Not Record. What Should I Do?
    Master:
  • 473 Answers
If your camcorder powers up but does not record, try the following: * Be sure that the camcorder is in camera mode. * Be sure that inserted tape is not full * Be sure that the protection / lock is not enabled on the tape * Try a new tape If your problem has not been resolved, find your nearest authorized service center.
Posted on Sep 06, 2005
SOURCE:
Samsung vp-d20 camcorder won't record sound
Take it back to the repairer. A connector may have come unplugged when it was re-assembled.
Jul 28, 2013 | Samsung VP-D20 Mini DV Digital Camcorder
I have JVC Hard Disk Camcorder GZ-MG145AA, my problem is everytime to record it the counter of recording is Red flash..means cannot record to my SD Card any Brand or to hard disk is say hdd Failure no...
you should check out your sd card whether it has virus or not or you may try to format you card.I think it may help you.... if not let me know i'll give you other solutions.
Apr 06, 2013 | JVC Everio G Camcorder
Camcorder wont record for longer than two minutes
hi Keven.
all i can find is the manual.
if you go to this link go to the 7th one down and that should be your manual.
plus at this link there is forums you can go in to that might help you out.
Hitachi DZ BX35A DVD Camcorder stops recording and says disc error Google...
Nov 24, 2017 | Hitachi DZBX35A DVD Camcorder
Vhs camcorder will record no picture
the camcorder will show previous recording but not record any new ones only showing snow or as if something is blocking the cap showing like a white snow
Oct 16, 2008 | Quasar VM-L152 Camcorder
Memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Sep 18, 2008 | Sony Handycam DCR-PC105E Mini DV Digital...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Should I use automatic or manual while recording?
Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shot™ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
Sep 06, 2005 | RCA CC-432 Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
64 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
