Question about Bosch HS2126 Breaker Hammer, 1-1/8" Shank, Tent Stake Driver
Breaker Hammers size question
How do I know which size of breaker should I use?
    President:
  • 2,712 Answers
After considering the application work, determine the carrier on which the breaker will be installed. Gorilla Hammers has assigned a 'Recommended Carrier Weight' range to each breaker. If the operating weight of the carrier falls within this range, the carrier will safely handle this model of breaker. If the desired breaker falls outside of this recommended carrier weight range, the carriers lifting capacity and oil flow will need to be verified to ensure a proper fit. Lifting Capacity: Provided the weight of the breaker does not exceed the maximum lifting capacity at any position, the carrier is assumed to be stable. On most loader backhoes and excavators, the maximum lifting capacity is lowest when the boom is at full reach. This is the value that must be compared to the operating weight of the breaker. Oil Flow and Operating Pressure: A required oil flow range is specified for each breaker. Oil flow to the breaker within this range is adequate for operation. However, for maximum productivity the carrier should be capable of providing the maximum required flow. Compare the maximum oil flow requirement of the breaker with the oil flow capacity of the carrier. Remember the breaker operates at 1500-2500-psi. therefore, oil flow should be evaluated at operating pressure.
Posted on Aug 27, 2008
Where do I put the oil?
Most breaker hammers have no oil if they have no high speed.
But special grease with high thermal conductivity.
very important .
If there is loose grease buy a consumables kit only complete , only then it makes sense.
Jun 07, 2015 | Hammering
What kind of oil do you add to a breaker hammer?
Bosch hammers and their clones use a PAG oil - PAG oil doesn't rot the various seals. The 'official' oil costs an arm and a leg, but the same oil can be had for topping up auto air/con systems.
Aug 11, 2014 | Hammering
Voltage going to the breaker, but know power comming out of the breaker
Hi, can you tell me how you are testing this power .. with a 2 probe tester, one on each leg?
Rememberr to reset a breaker, press firmly to off , then back to on.
Please Vote !!
May 13, 2010 | Cutler Hammer 200 Amp Circuit Breaker...
Need to know how to take appart the bosch brute hammer gear case? Spring shaft removal technique?
You can go to Boschtools.com and type in your model number for a breakdown, but repairing this tool is a headache.
Sep 20, 2009 | Bosch Brute Breaker Hammer 11304
Breakers how to
Aug 27, 2008 | Dewalt D25980R Factory-Reconditioned 15.0...
Breakers Question
This is the most critical factor in choosing the breaker size. SMALL HYDRAULIC BREAKERS (HAMMERS): up to 1200-ft.lbs. (1627 Joules), are typically used in concrete and other light duty work. MEDIUM HYDRAULIC BREAKERS (HAMMERS): 1200 - 4000-ft.lbs. (1627 - 5423 Joules) are used in both concrete and rock applications with limitations on the size and amount of material to be broken. LARGE HYDRAULIC BREAKERS (HAMMERS): over 4000 ft. lbs. (5423 Joules), are typically used in rock and large scale concrete demolition projects.
Aug 27, 2008 | Lisle 2 to 7in. Glaze Breaker Engine...
Breaker Hammers Features
power, raw strength, comfort and vibration
Aug 27, 2008 | Bosch 11335K Factory-Reconditioned 35 lb....
Bosch HS2126 Breaker Hammer, 1-1/8" Shank, Tent Stake Driver Logo
290 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
