Question about Do it Best Imports/ Jaun Yei 326409 Cable Staple Gun
Compare staple guns
What is the different between a staple gun and a hammer tacker?
  • Anonymous Mar 18, 2014
    loading staples
    President:
  • 2,712 Answers
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Posted on Aug 27, 2008
Tre550 stopped working
Problem is the safety micro switch. This is engaged when you press the gun against the surface. You can open the gun and short the wires. Do remember will not safety switch and hence you must ensure others know this - no children!
Apr 13, 2012 | Stanley Tools Hammer Staple/Tacker -...
The spring in Stanley TR45 light duty sharpshooter does not work, where can I get a new spring?
From what I have read, and I've searched, Stanley doesn't make parts for this staple gun. Only found hammer tacker springs.
Here is the phone number for Stanley customer service: 800-262-2161
It's a remote chance that one of those might fit.....
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Apr 06, 2011 | Stanley Tr45 Sharpshooter Light Duty...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Jul 07, 2009 | Arrow Fastener T27 Light Duty Household...
Staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
Do it Best Imports/ Jaun Yei 326409 Cable Staple Gun Logo
227 people viewed this question
Top Do It Best Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Do It Best Tool and Hardware - Other Expert? Answer questions, earn points and help others
