Question about Arrow T25 Staple Gun
Staple gun specifications
What kind of staples sizes are out there?
    President:
  • 2,712 Answers
Typical staple sizes are 1/4?, 5/16?, 3/8?, 1/2?, 9/16?, and 17/32? (6.4, 7.9, 9.5, 12.7, 14.3, 13.5 millimeters).
Posted on Aug 27, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
Where do I find staples for the above Ace 2025 staples?
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Apr 19, 2016 | Staples Tools & Hardware - Others
How do I adjust arrow manual staple gun to fit the sizes it recommends...one size seems to be too large
there is usually no adjustment for manual staple guns. you can only fit the length of staples that slide into the holder.
Mar 02, 2015 | Arrow Tools & Hardware - Others
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples Swingline® 36115 Staple Guns Tools...
Need to know staple sizes
If you get the model number off of your staple gun you can cross reference that with the listings on the staples box. A lot of the staple guns will also have the replacement staple sizes right on the bottom of the gun.
Nov 12, 2012 | Tools & Hardware - Others
What size staples do the 9.6v craftsman cordless staplers use?
Your staple requirements will be noted on the gun shoe ( staple magazine). Usually guns of this size take T-50 staples. Good luck with your projects
Apr 11, 2011 | Tools & Hardware - Others
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
My jt21m stappler gun is not dispencing staples, i have loaded it the only way i can see how to, helppppp
Make sure you are using the correct staples for your staple gun. Same brand, proper size.
Next look carefully where the staple should come out as often there will be part of a staple caught up in that area which will have to be pulled out with a pair of pliers.
Oct 03, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Arrow T25 Staple Gun Logo
531 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
