Question about Marshalltown Trowel Company Marshalltown Trowel Double Sided Brick Jointer - 8
Jointer Usage What are the uses of the jointer?
    New Friend:
WHAT DOES HJR MEAN IN MASONRY CONSTRUCTION
Posted on May 13, 2013
    President:
  • 2,712 Answers
A jointer has 2 uses. 1. it is used to make the edges of boards straight. If you look down the edge of any board, you will see that they are not straight. This is called a crown. by feeding the board threw the jointer, you will take the high ends down to make the board straight. This is necessary, excuse the spelling, for glue ups. 2. It is also used to flatten out a board. Same as the edge, the face could have a cup. By sending the face through the machine, this will make the board flat. Then you send it through the thickness planer to make the board symetrically even. You can use the jointer to make rabbets also, but there are other machine that will do the job better and faster, such as a router or a table saw, with or with out a dado blade.
Posted on Aug 27, 2008
I cannot level the tables on my jointer. When I place a level on my tables,the front of the in table is about 1/4" low. how do adjust it? Or better yet where can I geta manual?
Please go to this link, download the instruction manual, then read and understand it before using your jointer. Incorrectly adjusted, even correctly adjusted, jointers can be dangerous tools, and failure to heed the instructions can easily cost you the loss of a fingertip or worse. Only when properly adjusted with the jointer be of any worthwhile use, anyway.
For more detailed information and numerous good articles with details on how to tune and use a jointer, search google for "jointer tune up".
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 06, 2011 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Delta jointer, where do i find the wrench to loosen the nuts for the blade
go to Dewaltservicenet.com and with your model number you can download a schematic for this tool and also order the parts online. I tried finding them but there are too many jointers listed in the Delta category.
Apr 16, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
How do I Get rid of snipe?
Your intake side of the jointer is not high enough. You can run a test using tape to see. Hope this helps. Remember to vote if it helps. Thanks. Here is the link to a youtube video that will explain it. Its called Dealing with snipe on a planer / jointer / thicknesser
Dec 22, 2010 | Grizzly G0452 6" Jointer
Blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Mar 09, 2010 | Masonry Tools
How do I align beds on Jet jointer?
i found on some jointer/planers that this problem, is the way its designed. you can adjust the two feeds close but not close enough. what your supposed to do is push the wood thru one side with pressure on top and side(right hand), then when it touches blade slowly but steadily switch pressure part on the outfeed side. when you think anout it you are cutting an L shaped notch(until the end) so you dont want the side to be exactly parallel. table top jointers are tricky to use.
Mar 13, 2009 | Jet Masonry Tools
Masonry Jointer Usage
While the final effects of a stone or concrete wall are stunning, the work to make it beautiful is time-consuming and difficult. Tools are very important in masonry work. Having the right tools for a certain job make all the difference. Jointers come in many different sizes and shapes. Learn the various types and how to use them and you can make quick work of a difficult task. Use an e-jointer for narrower spaces between the stones. There is no handle on the e-jointer, making it easier to smooth and shape the joints between the stones. Whenever your hand is closer to the surface, you can exert more control. Get a bead jointer for raised masonry bricks. These jointers come in two sizes, 1/4-inch by 5/16-inch and 3/8-inch by 1/2-inch. They are small, strong, simple tools that can chip off the excess of a joint that is sticking up off the brink. You do not want to make a deep joint between raised bricks. Change your joint tool to a brick masonry mortar joint raker tool if you are making your project from rougher materials, such as adobe brick or split stone. This tool has many more grooves, which will fit in various sized joints. Turn it on the end for narrow joints and use the curved notch for more intricate patterns between the stones. Switch to a grapevine mortar jointer for very clean lines between the bricks. This tool is used primarily for a colonial look, which is even and measured. Your can get this jointer with a wooden handle for a more even grip.
Aug 27, 2008 | Delta Machinery Delta 37-658 Jointer...
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Marshalltown Trowel Company Marshalltown Trowel Double Sided Brick Jointer - 8 Logo
249 people viewed this question
Top Marshalltown Trowel Company Masonry Tools Experts
Tom Chichester
ray gallant
Are you a Marshalltown Trowel Company Masonry Tool Expert? Answer questions, earn points and help others
