Question about Sunhill Machinery Mobile Base for 6" Jointers
How to Replace Drive Belt
How Do I Replace a Drive Belt on a Perform 6" Jointer?
    President:
  • 2,712 Answers
Unplug the jointer. Invert it on a thick cloth to protect the blades and the work surface. Underneath you will see a base plate that covers the bottom and is held in place by seven screws. Remove all of the seven screws and set them aside with the baseplate. With the baseplate removed, you will see the power leads running to the main switch and back to the motor. Remove the hex bolts that hold the motor in place. There are two on one side of the motor (indicated by purple rectangles in the picture), and another one on the other side. Remove them completely to allow the motor sufficient room to move in order to place the drive belt over the motor spindle. If your hex key is not long enough for this job, hold the key in a pair of pliers or vice grip to remove them. (Now that the jointer is disassembled, this is a good time to clean all the motor housing thoroughly and lubricate, if applicable.) Lift and rotate the motor and attach the drive belt. The motor will not easily return to its normal position. In the picture you can see just how far the motor has been turned to get the drive belt on. Insert the hex bolts again, deep inside a very narrow space, whilst using a fair bit of force to hold the motor in place. This is the difficult part, and you may utter a few choice words at this point and consider some unauthorized modifications to the housing. With patience and persistence you should be able to secure the hex bolts once more and once again have an operational planer/jointer.
Posted on Aug 27, 2008
Where can I get a drive belt for a INCA PLANER/JOINTER
Hello.How about a power twist link belt ? You can make the belt the length you need,and it will also reduce vibration,a lot. I put one on an old Craftsman bandsaw,and it made a great difference.
Apr 12, 2012 | Tools & Hardware - Others
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
Blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Mar 09, 2010 | Masonry Tools
How do I replace the motor drive belt
  1. 180px-underneath_920.jpg magnify-clip.pngPictured here on a folded sheet on a carpet floor.Unplug the jointer. Invert it on a thick cloth to protect the blades and the work surface. Underneath you will see a base plate that covers the bottom and is held in place by seven screws.
  2. 180px-baseplateremoved_628.jpg magnify-clip.pngBase plate removedRemove all of the seven screws and set them aside with the baseplate. With the baseplate removed, you will see the power leads running to the main switch and back to the motor.
  3. 180px-hexbolts_779.jpg magnify-clip.pngTwo of the hex boltsRemove the hex bolts that hold the motor in place. There are two on one side of the motor (indicated by purple rectangles in the picture), and another one on the other side. Remove them completely to allow the motor sufficient room to move in order to place the drive belt over the motor spindle.
    • 180px-hexkeyextension_378.jpg magnify-clip.pngHex key "extension"If your hex key is not long enough for this job, hold the key in a pair of pliers or vice grip to remove them.
    • Now that the jointer is disassembled, this is a good time to clean all the motor housing thoroughly and lubricate, if applicable.
  4. 180px-twistedmotor_569.jpg magnify-clip.pngMotor twisted, drive belt belt attached towards bottom of pictureLift and rotate the motor and attach the drive belt. The motor will not easily return to its normal position. In the picture you can see just how far the motor has been turned to get the drive belt on.
  5. Insert the hex bolts again, deep inside a very narrow space, whilst using a fair bit of force to hold the motor in place. This is the difficult part, and you may utter a few choice words at this point and consider some unauthorized modifications to the housing.
  6. 180px-done_728.jpg magnify-clip.pngDone!With patience and persistence you should be able to secure the hex bolts once more and once again have an operational planer/jointer.
Jul 30, 2009 | Exercise & Fitness
Manual for Delta Shopmaster 6" Jointer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number. It will take you to another page and click on the first JT160 and when it changes screens click on the instruction manual, I had to click on it a couple times to open it but I did look at and it is about 48 pages long. Let me know if you have any problems and I will check further
Apr 04, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Need manual for Jointer
Go to this link and you'll find a complete parts diagram, list, and pdf manuals for your jointer.
Dewalt service net
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Cutter Guard for Jet Jointer JJ6
You may want to Call 800-727-9787 x5617 and request Part J-31 Cutter Hand Guardmoz-screenshot-1.jpgmoz-screenshot.jpg
Jan 13, 2009 | Masonry Tools
Need a manual for 1 3/8 hp, 6 1/8" jointer / planer
need a manual for 1 3/8 hp, 6 1/8" jointer / planer
Oct 28, 2008 | Masonry Tools
Sunhill Machinery Mobile Base for 6" Jointers Logo
191 people viewed this question
Top Sunhill Machinery Masonry Tools Experts
Tom Chichester
Are you a Sunhill Machinery Masonry Tool Expert? Answer questions, earn points and help others
