Question about Bailey Stanley 12-960 - Low Angle Block Plane
How to Fix Doors and Windows?
How Can I Fix Doors and Windows with a Held Power Planer Tools?
    President:
  • 2,712 Answers
Take a look around the house or any place where you're using doors that don't swing clearly open and closed. Check to see that the door doesn't have a problem with its hinges but is actually a millimeter (or a few) too large on the top or bottom, since this is a perfect use for held power planers. Look for ragged or rough edges on wooden planks built into things like handmade bookcases. Also find imbalances on the bottom of wooden chairs and tables that cause an annoying rocking that is easily corrected by the held power planer. Use the planer to make rabbets (sometimes called rebates), or smooth and even grooves in a piece of wood that can accommodate the edge of a piece of glass, sealant or putty. Thin out pieces of wood used for do-it-yourself jobs if the wood expands from humidity and moisture. Let the wood settle in the place that it will permanently sit and then user the planer to plane the wood to the correct size. Do the work in the place that the wood will occupy if it's feasible. Take a look at wooden window frames that cause the window to stick or open and close roughly. Plane the window frame a millimeter at a time to get the window to run correctly.
Posted on Aug 27, 2008
Is there a repair manual for this planer?
iFixit: The Free Repair Manual
https://www.ifixit.com/
iFixitiFixit is a global community of people helping each other repair things. Let's fix the world, one device ... We stopped by the European Parliament in Brussels to show some folks there how to fix their phones. The repair-focused ... Fix the Planet.
Shopsmith Repair Manual Planer - womensvictoryopen.com
dull69.womensvictoryopen.com/shopsmith-repair-manual-planer-xuvjjqe.pdf
Shopsmith Repair Manual Planer. Shopsmith jointer manual - free eBooks download. Shopsmith jointer manual download on apexjournals-3.org free books and ...
Dec 02, 2015 | Tools & Hardware - Others
Dewalt 735 planer wont start
Power? circuit breaker? Plug? Owner's manual. Troubleshooting
Does the motor hum? if so you have something jamed in the planer cutter.
Feb 28, 2015 | Dewalt Tools & Hardware - Others
I need a copy of the owner's manual for Dewalt's Dw733 power planer...please
Check the planer product label on your DW733. DeWalt has two DW733 (type 1 and type 2) models. The manuals for the DW733 is available on the product page: http://www.dewalt.com/tools-discontinued/machinery-portable-thickness-planers-dw733.aspx . See the drop-down list of documentation on the right side of the page. You'll see a pop-up page with more documentation available on the right side of the page. Scroll down to the Instruction Manual.
I hope this helps.
Dec 13, 2011 | Tools & Hardware - Others
Could there be a blown fuse to prevent this from starting, I turned it on and the motor stated for about a blip of second, my electrical panel was not triped though
I answer questions for free.
Your model planer might be different than mine.
My 12" planer has a red reset button on the motor.
There could be a loose wire in the receptacle.
Check the receptacle for power.
Your product manual should have an illustration of the reset button.
The power tool companies do not have manuals for every model number, but they have service centers.
Nov 01, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
The planner nips the end of the board
My planer does the same thing.
1) I don't make the final cuts on my boards until after planing.
2) I discovered why the planer does this. I don't have a planer table. I use the two metal stands that came with the planer, and they don't really hold the board flat & steady like a planer table would. The planer has 2 rollers >>> one roller is on the feed-end and one roller is on the finished-end. When the end of the board goes past the feed-end roller, it is no longer held flat by two rollers. The weight of the board causes the board to tip up into the planer blade on the last 3 inches. So sometimes I just hold up the end of the board as it finishes ... but it still takes a nip out of the board now and then.
Up-vote if the information helped you. Thanks for the feedback.
Oct 15, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
I am trying to replace a belt on a Ryobi 10 inch surface planer, but I haven't found a tension release. How do I replace the belt
I thought one of those belts, pulleys, had a screw on the end holding a washer. Pull the screw off and the washer, and the belt should slip off. It has been a while since I have had to go in there, but I remember that much. Unless it was a hand held planer I had. I would have to go and peek at it. Check it out.
Apr 19, 2010 | Tools & Hardware - Others
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Planes Comparison
If you have a stack of hand planers and you do a lot of woodworking, you might want to buy a power planer. Power planer have a number of qualities that should convince you to keep the old hand planers but add that power to the group. Choose a power planer when you have a lot of planing to do. One thing about a power planer is that it is much faster compared to the hand planer. Use a power planer when you need to make rabbets or even scrolling. The power planer can do both of these jobs. There is a great deal of versatility about a power planer. Keep the cut smooth with a power planer. Frequently a hand planer needs to be lifted and started again. This leaves gouges and groves. A power planer has a continuous blade that leaves a smoother cut. Get more precision. The continuous motion of the hand held power planer and set depth cuts the specific amount that you want. Plane larger areas. You can plane doors quickly and easily with a few strokes of the power planer. Straighten a board easier with a power planer. You also can create chamfered surfaces with the power planer.
Aug 27, 2008 | Rockler Carbide-Tipped Radius Plane &...
Bailey Stanley 12-960 -  Low Angle Block Plane Logo
782 people viewed this question
Top Bailey Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Bailey Craft and Hobby Expert? Answer questions, earn points and help others
