Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Sound Problem Camera Has No Sound In Play Back Mode. The Volume Control Has No Effect.
  • Hamhoxx Nov 30, 2007
    I have made sure to be in playback mode and I have toggled the speaker on and off. Still nothing, help please
    Master:
  • 473 Answers
Be sure you are not playing back in "camera mode". If this is the case, change the power switch to "play mode" and resume playback. This should solve the problem. Some models have a Speaker On/Off function in the menu as well. Consult the User Manual for more information.
Posted on Sep 06, 2005
SOURCE:
Subwoofer powers on ok, volume level stays at mid to high range. Adjustment on back has no effect or distorts sound a bit please help
If you have plugged the input to the LFE socket the volume control may not have any effect coz' its ment to be controlled by the AV receiver in this mode. Connect to the L/R scoket ( any one will do ).
Sep 26, 2011 | JBL Venue SUB10 Subwoofer
How I can sapture a picture in ISO mode??? what is the purpose of capturing aphoto in ISO mode??
ISO is not really a "mode", every photo you take has an ISO rating; it's one of the three main ways of controlling how light or dark a photo is. (The other two are shutter speed - how long the sensor is actively capturing for, and aperture - how wide is the hole (aperture) that the light passes through.)
You can think of the ISO rating like a volume control - it's how sensitive the sensor is. At ISO 100 the sensor is at its least sensitive - you get the smoothest picture but you need lots of light to do it. At ISO 800 and higher, your sensor is most sensitive - your camera will take pictures in lower light, but there will be more 'noise' - meaning the speckled effect you get on digital pictures.
It's similar to the volume control on a radio. When you have a strong local station you can turn the volume down, and you'll still get a great quality sound. But if you are trying to pull in a distant station, you turn the volume up and put up with a bit of hiss just to hear what they're saying.
Just the same with a camera. When you have strong sunlight, you can turn the ISO down and you'll get a great picture. But if you're trying to pull in a dark photo, you turn the ISO up and put up with a bit of speckling, just to see the image.
Hope this helps.
Feb 02, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
HOW DO I GET TO VOLUME
there is generally no sound on the video part of the digital camera. you have to upload it and play it on the computer to get the sound.
Jun 16, 2009 | Kodak EasyShare C513 Digital Camera
Camera mode dosn't function. Play mode functions.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $105 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Mar 21, 2009 | Olympus Camedia C-480 Zoom Digital Camera
No volume on play back.
I hope this doesnt come across condencending as you're used to cameras, but to clarify, the monitor volume on the camera is up yes? Both the volume control and the monitor volume - both in camera?
Jan 22, 2009 | Sony HDR-SR10E HDD Camcorder
No sound when recording video
Did you set up the camera to capture sound? This Camera has a Functions menu which is deep as the ocean, and standard movie capture does not also pick up sound. Additionally, if playing the movie back over an external device, use the A/V cable not USB, and get a High Capacity SD/MMC memory card if you want more than a few moments of video with sound. I would finally recommend an audio input device, as even when in Movie sound capture mode, the volume is never very loud.
Read the advanced manual completely.
Dec 25, 2008 | Canon PowerShot SD1000 Digital Camera
Hp zv5346us audio problem
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Oct 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
How do i get sound to work in recorded movies
Some cameras you CANNOT play back on the camera, but it only works on the computer. Nothing is wrong, because that camera is basic. So yeah.
Dec 18, 2007 | Sony Cybershot S650 Digital Camera
Sound
check if the digital compression option is off.turning it on should make the sound equal.also might want to check your volume setting on the main menu when you turn it on.only problem is you need the remote.hope this helps in some way.
Sep 05, 2007 | Koss KS3102 System
Menu Options
sound or volume can be lowered or turned off using zoom control button
Aug 30, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
51 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
