Question about Casio Cassiopeia E-125 Pocket PC
E-125 No Power
I've had a Casio E-125 for 18 months and it turned itself off and would not turn back on. I purchased new batteries and charged them as instructed prior to attempting to restart my E-125. It failed to start. As others have written regarding the same problem I too was able to get it to power on for a limited amount of time by fiddling with the batterings and doing a full re-start. It doesn't maintain power prior to going dead for very long. I'm not sure if I should take this thing apart. I believe it has turned to junk as probably planned. If anyone can offer some help it will be appreciated. Thanks
    Master:
  • 551 Answers
Hello, The E125 and most of the CASIO HPC's have problems similar to this. Unfortunately you will loose any data you have input since your last backup with the solution I am about to give. First, leave the unit plugged in and charging for at least an hour. Next, remove all batteries, main and backup. let the unit sit for a while to discharge any capacitance in the circuit. If possible short the + and - contacts on the unit (NOT the battery). This will discharge capacitance in the circuit. Then, press the reset button. Replace the main battery and press reset again. The unit should power up to factory defaults. Replace the backup battery. You will need to sync with your PC to restore data. If this doesn't work, you may have a completely discharged NiCd or NiMH battery and it will need replacement.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
I may have the same problem (maybe). Mine does that if I use the charger. So what I do is swap batteries. It 1st happened in Jan. What got it going again was toggling the battary switch to the remove main battery position and leave it there for a little while. I have a seperate BAttery with its own charger and when I dont Plug in the Power Supply to the Em-500 I never have the problem. I was doing programing and had plugged it in and sure enough it started happening again. You might try leaving that switch toggled or remove the main battery over night especially if you have the backup in place. If you have the same problem thats what gets mine going.
    Master:
  • 551 Answers
Are you checking your adapter. i had the same problem with my casseopeia e115. i searched and searched for the battery which even casio doesn't offer anymore. i bought a battery pack which works great w 4 AA batteries but it's bulky and you lose data when you turn off the batteries. i finally went on to discover that my charger/adapter that plugs into the e115 and the serial cradle was scorched by a lightening strike and it was not charging and eventually the batteries DIED!!! I took the adapter to an electronics repair store and for $15.00 they rewired the adapter and it works!!!! it charged the batteries and worked fine.(altho i have to visit them again because i think one of the new wires is bent and i have to position it perfectly to keep charging.) BTW: any one looking for a new casio battery jk210lt...i have a couple to sell! ;-) hope this helps
SOURCE:
I've got a Dell Studio 1735 that started to tell me the battery was on the way out after 18 months (maybe a bit more). One day the battery stopped charging and when it ran down completely it...
There is a short circuit on your motherboard. This is why the power adapter switched off (thermal cutout) and resets after you remove the adapter from the wall power outlet.
You need a new motherboard.
Aug 19, 2011 | Dell STUDIO 1735 Motherboard - H274K
I cannot get my casio exilim 7.2 pixel camera to power up I have tried charging the battery, but the red light shows for a minute then it goes off When i insert the battery in the camera, it powers up...
If the light blinks while charging then it means that you have a faulty battery and it needs to be replaced. Usually they only last if you're lucky 12 months so I would suggest replacement of the battery and that should solve your problem. :)
Sep 11, 2008 | Cameras
Red Flashing Charger Light
I have HAD the exact same problem. Turns out a whole bunch of people too. But there is a solution. You can get a free new battery by calling the casio technical support. 1-800-435-7732. They are very friendly. They'll ask you a few questions, like where you live, you number and your camera serial number[ under your camera ] and all you have to do is explain to them your problem. I got my new battery and now my camera works as good as new.
May 13, 2008 | Casio Exilim EXZ75 Digital Camera
Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
Exilim Power Failure
Well hopefully only the charger has be destroyed Can you get a new charger and also a new battery? Check out the Casio Website for availablilty
May 27, 2007 | Casio Exilim EX-S500 Digital Camera
Battery and Charger problems
Only a new battery I venture what type of battery is it?
May 26, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My E-125 isn't working properly...
If your craddle has DC power input that charges the PDA while in craddle, try setting the power configuration so that when the PDA is on external power, there is no blank screen timeout, and no automatic shutdown (it's in the Settings menu). This way, it won't power down while in craddle, and you won't get this problem you're having.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 Turns off and won't turn on
This is what I suggest: Get yourself a new backup battery. First backup your Casio. Then install the main battery. Plug the Casio in and recharge overnight. Once recharged, install the new backup battery. Make sure you do not touch the battery with your hands. Use a tissue. This should solve your problem if the Casio is not physically damaged.
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
159 people viewed this question
Top Casio Computers & Internet Experts
k24674
Joseph Hoffmann
Vincent_G
Vincent_G
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
