Toshiba 27AF41 flat screen tv is out of focus in the lower corners for about 3" in. It is most noticeable on satellite CNN with the logo in the lower right and scrolling text. Adjusting the contrast from the on-screen menu helped some but it is still irritating. Is this an adjustment that can be corrected by a technician or could it be caused by the satellite signal? Thanks for your help. Thanks. Thanks, Richard
It is not caused by any satellite signal. Does it get better or wrost as the set warms up? Set contrast at mid level and adjust bright from minimum to maximum - how much is the difference? Does the corners get acceptably focused with minimum bright? If you set contrast and bright to max, how is the focus at the center of the screen? How did it started doing that, suddently or progressively? I would say you have a CRT which is beginning to go weak, or you have some problem with the Focus/G2 divider, or the dynamic focus circuits do not work. The focus adjustment can help, but if it's really the tube, it's not a good sign. You should have a competent tech take a look, and at least readjust the focus and see if it improves.
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote....
(More)
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote. While in the off mode what are my solutions to make my tv turn on? Someone plzzźżž help because tired off my classical television that only recieves 36 channels.
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it...
(More)
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it on? I have tried what it said by unplugging it and waiting 2 minutes and then replugging it back in. This problem seems to continue to occur even after 3 hours of it being unplugged. Please help asap and thank you.
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I...
(More)
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I press the power button again.
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I...
(More)
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I press the power button again.
