Question about Dewalt DC7KITJA 18v. Xrp Super 7 - Kit Cordless Combo with Right Angle Drill & DC330 Jig Saw
Jig Saws power
How can the power of the motor effect my work?
    President:
  • 2,712 Answers
The more power the jigsaw has (measured in Voltage for cordless and Wattage for corded), the faster the cuts and the deeper they are - up to 70mm in timber or 8mm in steel.
Posted on Aug 27, 2008
WHERE CAN I BUY A battery nteCBA18 for a jig saw model ntecjs8c from northern industrial?
try at http://www.ag-central.com/ag-store/Power-Tool-Accessories-148.html or contact Norther Industrial tools at http://www.northerntool.com/shop/tools/category_power-tools+jig-saws
Feb 05, 2017 | Saws
WHEN I USED OLD TABLE SAW WITH UNGROUNDED POWER CORD. I ALSO HAD JIG SAW PLUGGED INTO SAME OUTLET. wHEN I LAID THE JIG SAW ON THE TABLE SAW IT SPARKED AND THE MOTOR ON THE POWER SAW DOESNT WORK. NEX
If you're lucky, there's a circuit breaker built into the table saw motor and a little red button somewhere on the motor to reset it.
When you re-wire it. know that the cord should have a black wire (hot), a white wire (neutral), and a green wire (ground).
When you wire the power cord to the switch, the black wire should be the one that goes directly to the switch contacts and gets disconnected when you turn off the switch. The white wire goes through the rest of the system up to the motor. The green wire grounds out the metal parts that you might touch.
If you have to replace the motor, get a 3450 rpm to 3600 rpm motor. Harbor Freight has one for about $140 before any discount.
I recommend at least 1.5 HP
Sep 16, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
Motor goes round in the dewalt but there is no drive.
check bearing and brushes, this was my problem on my SKIL 4280.
Mar 28, 2010 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
I have an old and very heavy cast iron Delta jig saw. I need to replace the oil in the lower end sump. What type oil is needed?
generally any machine oil will do, The oil needs to be lighter than motor oil, but thicker than pneumatic tool oil. I would bet that compressor oil would work, it is relatively inexpensive and I believe thin enough for that application
Jul 08, 2009 | Saws
My cordless jigsaw doesnt seem to give out as much power anymore and its not the batteries
The commutator on the motor is probably dirty. Use a light grade sand paper and turn the motor by hand while you clean it.
Jun 24, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Dewalt DC7KITJA 18v. Xrp Super 7 - Kit Cordless Combo with Right Angle Drill & DC330 Jig Saw Logo
117 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
