Question about Porter Cable Cable 53530 Edge Guide for Model 9543 Quik - Change Jig Saw
Jig Saws Adjustable foot
What is an adjustable foot?
    President:
  • 2,712 Answers
An adjustable foot is the metal plate at the bottom of the saw which will pivot between 0 and 45 degrees. This will allow you to make angle cuts in the wood
Posted on Aug 27, 2008
How many board feet are there in 18' x 28' room. 1 in
4,032bd ft. if the room is completely full and has 8 foot tall ceilings.
May 19, 2015 | ShopWoodworking Discountable , Rough...
How to change blades on a bosch 1587avs
Turn the handle on the top counterclockwise like shown in the video.
But the handles break often, see the link for a parts breakdown
Bosch nbsp1587AVS nbspTop Handle Jig Saw
Feb 09, 2015 | Bosch 1587Avs Jig Saws
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
Can't turn trolling motor with foot control
Jigsaws only usually have one motor, for the blade, not for trolling.
What make and model of Jigsaw is it?
Oct 12, 2013 | Saws
Adjusting depth of blade
generally you dont adjust depth of blade, you buy the blade in different lengths to suit the job and material
Jul 11, 2009 | Black & Decker Saws
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Porter Cable Cable 53530 Edge Guide for Model 9543 Quik - Change Jig Saw Logo
128 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
