Question about Master Appliance 650DG F MASTERMITE MASTER HEAT GUNS
Heat Guns Features
Which features are differences between one model of heat gun and another?
    President:
  • 2,712 Answers
As such a simple tool, there are not many differences between one model of heat gun and another - but there are some features which are important. * Wattage - commonly from 1000W to 2000W (a measure of the power of the gun). Providing that there are heat and/or airflow controls, the higher the wattage, the better. * Main control switch - usually mounted on the front of the pistol grip, and normally a 'dead man' switch so that power is switched off when the finger pressure is removed - an ideal safety feature as the heat gun stops if it is accidentally dropped. * Temperature setting - at least 500°C is needed for stripping paint - the lower the bottom end of the range the more useful. A choice of controls make the tool more useful. * Airflow setting - having variable or more than one speed makes the tool more versatile. * Thermal cut out - this will switch off the tool if it becomes overheated. If this occurs, it indicates a fault in the tool or method of use - for safety, the fault must be identified and corrected before the heat gun is again used. * Flex length - lengths of 2.5 to 3 m are normally fitted, this means that when using an extension lead, the tool can be used at the full reach without having the socket hanging in mid air. * Hanging hook - useful for storing the tool. * Surface stand - this enables the heat gun to be safety 'rested' during pauses in the work and after uses. It also allows the gun to be used 'hands-free' when two hands are required on the work piece (such as when bending a plastic pipe). * Nozzles - most heat guns have a range of nozzles that can be fitted for specific uses, generally these need to be purchased separately. The main types of nozzles are: 1. Reducer nozzle - when you want to concentrate the heat onto a specific area. 2. Reflector nozzle - wraps round a plastic or copper pipe to spread the heat around the pipe surface. 3. Flat nozzle - for spreading the hot air over a wider narrower area. 4. Glass protector nozzle - for use when stripping paint on a window to keep the direct heat off the glass.
Posted on Aug 27, 2008
I need a wiring diagram for the trigger mechanism for a POWER-CRAFT soldering gun model 84 TWL 6091A.
You need this part: Weller 7324 Switch for Dual Heat Model 8200, D550 and D650 Soldering Guns That will repair the unit. Wire diagram is inconsequential .
May 18, 2016 | Welding Tools
Where is the fuse for the seats chime on 2006 silverdro chevy
If it were only that simple. The fuse that controls the seat chimes controls other features that you don't want to lose. Sorry.
Nov 06, 2015 | AEM 2006 Chevy Silverado - 2500HD, 6.6L...
What are the latest airsoft upgrades?
The latest electric gun in today's market is the hybrid gun of airsoft. The hunting and shooting process can be done properly with the use of these hybrid guns. Laser sightings and torches are used for comprising the parts of Airsoft gun.
Sep 18, 2014 | Ics MP5A5 Airsoft Gun
What stainless steel staples to fit any plier stapler are available in australia?
Since you didn't list a brand and model nimber, it's hard to say. Staplers are different. They either shoot wide or narrow, or thick or thin or, a combination of these features. Take it along when you go to buy staples.
Apr 24, 2013 | Tools & Hardware - Others
What is the difference in temperature between low-heat and high-heat glue guns?
Low-temperature glue guns operate around 250 degrees Fahrenheit and are more suitable to gluing materials that can be damaged by higher heat, such as lace or cloth. High-Temperature glue guns operate around 380 degrees. Generally, the higher the temperature you use, the stronger the bond will be.
Feb 26, 2013 | Crafts & Hobbies
My heat gun model hg1000k has stopped working while I was using. It is not very old.
Most heat guns have a cool down mode on them after you use it and it takes a bit of time to properly function if this time allotment was circumvented they tend to burn out their coils. The coil can be checked with a multimeter. Also you can check the trigger and power cord
Apr 10, 2011 | Black & Decker Black and Decker 1500w...
Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
Mar 24, 2009 | Weller D550PK Professional Soldering Gun...
CAN i USE THE HEAT GUN TO WELD VYNAL TOGETHER
You need the proper type of heat gun and the proper type of filler. It is mainly used for thicknesses over 1/4". The vinyl on a lounge would melt away from the ambient heat created by the gun.
Mar 11, 2009 | Master Appliance 650DG F MASTERMITE MASTER...
Heat Guns Troubleshooting
Uses for the heat gun include: * drying paint or varnish - 30 to 130 °C - care has to be taken as dust particles may be blown onto the paint/varnish. * drying out damp wood (before filling or painting) - around 100 to 200°C. * softening adhesive (such as when applying worktop edge trim or lifting floor tiles) - 300 to 400°C. * bending plastic pipes - 200 to 300°C. * heat-shrinking plastic film - 200 to 300°C. * welding some plastics - 330 to 400°C.
Aug 27, 2008 | B O X Packaging Variable Temperature Heat...
How does it work?
Heat guns look a lot like hair dryers - but, as many instructions thoughtfully point out, should never be used for drying hair! The method of operation of a hot air gun is similar to a hair dryer: a fan pulls air into the body of the tool and drives it across an electric heating element and out through a nozzle. For stripping paint, the heated air is directed onto the painted surface, causing it to soften so that it can be easily stripped off - either by using a stripping knife or hook. For best results it is best to work up the surface with the heat gun above the stripping tool, softening the paint just before the stripping tool reaches it. The tool is used one-handed, with the other hand to hold the stripping tool. Some heat guns can be used sitting on a bench so that two hands are free to use the hot air for other applications.
Aug 27, 2008 | Master Appliance 430/840 DF PROHEAT MASTER...
Master Appliance 650DG F MASTERMITE MASTER HEAT GUNS Logo
301 people viewed this question
Top Master Appliance Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Master Appliance Tool and Hardware - Other Expert? Answer questions, earn points and help others
