Question about B O X Packaging Two Temperature Heat Gun
How to heat gun
How Can I Use my Heat Gun to Remove Old Carpet Backing From Tile Floor?
    President:
  • 2,712 Answers
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Posted on Aug 27, 2008
I have a 12x12 vinyl stick down tile in the middle of the floor with a rock or something under it. how do I replace it?
If it is 12 x 12 tile, and not sheet with a 12x12 pattern you should be able to get a corner up and just peel the one square out.
If it's a sheet with a 12x12 title pattern and the bump is small, you can put a metal putty knife flat over the bump and hit it once with a hammer to see if you can flatten it. If the bump is large you're going to have to do a clean cut to remove it, the use a heat gun and a metal putty knife to flatten it out afterwards.
Oct 16, 2015 | Building Materials
Our self sick vinyl tile won't stick what can you do to get it to stick? We are just installing.
are you putting this over concrete? Is the concrete "clean" meaning your not putting it over glue. I am guessing if this is a new install it is a problem with the floor itself.
Feb 21, 2015 | Building Materials
When I had floorboards put in, my little boy stepped on the glue(with shoes) and transferred to tiled area which has got that uneven surface(not smooth)
To remove the glue - assuming it is in fact a heat glue - you need to heat it and get it to stick to something else.
Normally you put a brown paper bag over the stuff and iron it with a normal domestic iron. If the surface is *really* uneven then heating it gently with a hot air gun then pressing a paper bag on top will work as well.
Use brown paper because it is more absorbent than other papers. Don't use newspaper because it has a habit of transferring ink to the other surface. You can also use a piece of cotton sheeting and even kitchen towel works too.
If you're talking about the "basically flat but slightly uneven surface" of a tile used on the kitchen floor, I'd probably use a couple of sheets of kitchen towel with a good texture pattern. Press a hot iron on top to transfer the heat and the glue will come up easy.
A final wipe with mineral turpentine will help to remove the last of the waxy residue.
Jun 18, 2010 | 3M 5/8 x 8 - Low-Melt Adhesive Clear
Linoleum has curled up beside bathtub
There probably is a reason that it curled and I would guess it is because of moisture getting behind the linoleum. If the linoluem wasn't sealed properly where it meets the tub, that could be the reason. I would use a good grade of construction adhesive (Lowe's, Home Depot....) BUT clean and dry the area you are going to bond to VERY carefully. Remove any old debris or glue. BE CAREFUL if you use a heat gun. It will melt cheap linoleum in a second. Try a hair dryer first and be patient....Once you have it glued (followig the mfg. instructions on the tube), lay something(s) HEAVY on the linoleum and let dry overnight. THEN run a bead of grout and tile sealant along the edge. Good Luck.
Nov 30, 2009 | Crafts & Hobbies
How do i remove all of the old fabric &foam off of the backer board?
use a heat gun to heat {not toast} and this will soften the glue, be careful with your hands because that hot glue makes you scream if you get it on you, you can use a paint thinner to disolve the left over foam as long as the backing board is timber and NOT plastic. if your going to recover it, use an abrasive paper to scour it for a really good bond. Good luck
Nov 20, 2009 | 1997 Jeep Grand Cherokee
CAN i USE THE HEAT GUN TO WELD VYNAL TOGETHER
You need the proper type of heat gun and the proper type of filler. It is mainly used for thicknesses over 1/4". The vinyl on a lounge would melt away from the ambient heat created by the gun.
Mar 11, 2009 | Master Appliance 650DG F MASTERMITE MASTER...
Heat Guns Safety tips
Although safer than using a naked-flame blowlamp, care is still required when using a heat gun. Specific point are: * Because of the power of these tools (up to 2000W), when an extension lead is necessary, only use a lead rated at 10 amp or greater and always completely unwind the lead. * Never obstruct or cover the air inlet grills. If the air flow is reduced the heat gun will overheat and possible catch fire. * Never operate the heat gun with the outlet nozzle hard up against a surface, this will reduce the air and can have the same effect as obstructing the air inlet grills, * Do not use a heat gun near inflammable materials. * Always switch the tool off before putting it down on any surface. * Allow the tool to cool before storing it. * Do not place the nozzle next to anything whilst it is hot. * Never touch the hot metal nozzle with clothing or skin. * Do not use for stripping lead-based paints. * Do not allow any paint to stick to the nozzle - and if some paint does stick, allow the gun to cool down and remove the paint. * Do not look down the nozzle while the gun is turned on. * Do not insert anything down the nozzle with the gun.
Aug 27, 2008 | Master Heaters 200-300DEG 120V MASTER HEAT...
Heat Guns Troubleshooting
Uses for the heat gun include: * drying paint or varnish - 30 to 130 °C - care has to be taken as dust particles may be blown onto the paint/varnish. * drying out damp wood (before filling or painting) - around 100 to 200°C. * softening adhesive (such as when applying worktop edge trim or lifting floor tiles) - 300 to 400°C. * bending plastic pipes - 200 to 300°C. * heat-shrinking plastic film - 200 to 300°C. * welding some plastics - 330 to 400°C.
Aug 27, 2008 | B O X Packaging Variable Temperature Heat...
B O X Packaging Two Temperature Heat Gun Logo
224 people viewed this question
Top B O X Packaging Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a B O X Packaging Tool and Hardware - Other Expert? Answer questions, earn points and help others
