Question about Makita Orbital Reciprocating Saw 2500 Spm, 115 Volt, 9.3 Amp
Orbital or Straight Comparison
What is the difference between the types? (Orbital or straight)
    President:
  • 2,712 Answers
An orbital reciprocating saw moves in a more elliptical or oval shape rather than just up and down. This makes it more aggressive and gives it a faster cut. Straight reciprocating saws move on a single plane, back and forth.
Posted on Aug 27, 2008
New APN info is not working complete
There are different types of APN set up for Straight Talk. My recommendation is that you add more APN from Straight Talk and select each one to troubleshoot. See, believe it or not, there different APN for different smartphone. You just need to select the right one.
Try this setting here if it's different from the one you have.
http://apn.gishan.net/settings/500_11_straight_talk_apn_settings_for_sony_xperia_z.php
Mar 24, 2014 | Sony Ericsson Cell Phones
Head light type
If you can pull the bulb, you can take it in to the auto parts store for comparison. But any auto parts store should be able to tell you the correct replacement bulb with or without the old bulb. They'll just look it up for your car make and model in their parts computer system. I prefer to have the old part in hand for comparison, though. If you haven't removed a headlight bulb before, it's pretty straight-forward these days. The hardest part may be fitting your hand into the space so that you can pinch the tabs and pull the connector off. I had one car where I had to access the bulb through the wheel well by removing a panel. The bulb itself is typically "bayonet" mounted - usually twist counter-clockwise until it stops, then pull it out. My Mazda is much older, so I don't know the configuration of your headlight access. Too often these days you have to remove panels or other items in order to have access to the bulb. Hope yours is one of the easier ones.
Mar 07, 2014 | 2006 Mazda 3
Difference between straight and low straight
BWhile both are straight legged one pair also has a low waist.
Jan 07, 2014 | G-star Raw ATTACC LOW STRAIGHT Straight...
Do straight barbells come in different weights?
Straightbarbells come in different weights. In my gym, we have three different straightbarbells. We have a light one, which weighs 11 kg, a regular barbell thatweights 20.4 kg, and a thicker barbell that weighs 21.4 kg.
Jul 25, 2012 | Exercise & Fitness
How to compare contents of two external hardrives?
Here are some free utilities/tools that can help you do a directory/file comparison. My favorite is Windows Commander but they changed the name to Total Commander. Its FREE though! You can find out more about this utility at the following website. http://www.ghisler.com/Or go straight to the Total Commander download page. http://www.ghisler.com/download.htm
Other sites offering free file/directory comparison utilities/tools.
http://winmerge.org/
http://www.redferret.net/?p=12872
Apr 20, 2012 | Computers & Internet
How do I change a blade with the Bosch 1587VS?
you need to lift up on the knob to loosen the spindle and remove/install the blade. To install the blade you might need to turn it some and push up and when it is straight then you need to turn the knob while holding up on it till it is snug and then push the knob down.
Jul 10, 2011 | Bosch 1587avsp Vs Orbital Jigsaw
Hello I have a compressor and my electric orbital sander has finally gone legs up. My question is if I get an air sander primarily for sanding wood is a straight line the best sort to get or are the...
I work in a wood working shop and we use orbitals on everything. You still will still sand with nice even strokes with the grain. It leaves a great finish. They are nice, light, and easy to use! They do use a lot of air though, so make sure your air compressor can handle the one you buy. If you compressor is constantly running you might have to take breaks so you do not burn it up. enjoy!
Apr 11, 2011 | Sander Viking Air Tools Dual Piston...
Blade won't stay straight
Use a higher quality blade, this will help.
It happens with a Jig saw. You have to mind the direction of the force you push on the unit.
A better blade will cut easier and faster and will be less likely to bend.
ALSO: this tool has orbital. This feature makes the unit cut much faster but is much less accurate for cutting. If you need to make a really straight cut, make sure orbital is off.
Nov 20, 2009 | Milwaukee Tool Milwaukee 6266 - 22 6.2 -...
My Makita BJV180 jigsaw will not do elliptical cutting even though I turn the lever to the elliptical cut position.
this saw has 3 orbital settings and one straight line setting .. in orbital mode the blade moves forward slightly on the up stroke and back on the down stroke .. it may be difficult to see and may not be pronounced without a load ...
Nov 12, 2009 | Makita BJV180 18V Lxt Lithium Ion Cordless...
Makita Orbital Reciprocating Saw 2500 Spm, 115 Volt, 9.3 Amp Logo
258 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
