Question about Dewalt Delta DP300L 12" Twinlaser Crosshair Drill Press
Drill Presses Models
What kind of models does the drill press have?
    Sergeant:
    Habit-Forming:
  • 142 Answers
The quality of DELTA DP300L 12" Bench Drill Press is equal to the price. It's better than a hobby drill press but not quite as good as a professional "shop quality" drill press.
The setup and assembly instructions were OK. But there were many opportunities for mistakes in assembly that could be more explicitly addressed. Specifically, I recommend assembling the drill press - but leave off the laser unit and the bracket for the tool tray. Leave the bolts a little loose. Then using the base plate as the reference point, use a carpenter's square to align the other components (so everything is aligned with the same centerline. Now tighten everything down and add the laser unit.
If you want know about the best drill press go to the link Best Drill Press In 2018
Posted on Feb 26, 2018
    President:
  • 2,712 Answers
When shopping for a drill press, you'll have to choose between two basic models: 1. Bench-top drill presses mount directly to a workbench or on their own stands. Their compact size makes bench-top models good choices for small shops. 2. Floor-model drill presses usually have more powerful motors, more attachments/accessories and greater material handling capacities than bench-tops. The extra versatility makes floor models good choices for serious DIY and commercial shops.
Posted on Aug 27, 2008
Removing chuck from a sears & roebuck model 113.24611 drill press
It is a morris taper wedge fit, so just tap it out.
Dec 29, 2016 | Sears Drills
How do you get a morse taper chuck out of a guardian power 12 sp drill press
Everywhere there is the same kind of remove or by a long axle insite the top pulley down
How To Remove Morse Taper Mounted Chuck From Drill Press AutoDrill
Mar 17, 2013 | Delta 15 331 15" 115/230V Variable Speed...
How do oscillating drill presses work? I have an old Craftsman 8 inch drill press with spindle sanding capability, but the spindle will not oscillate up and down.
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Jun 11, 2011 | Craftsman Drills
I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
Apr 15, 2011 | Craftsman 12" Drill Press (21914)
I don't really have a problem, I bought a used Clarke Metalworker model BT1001A and I need a manual for it. Can I get one from you? If so, how much? Demi skypilot2@sisterlakescable.com
Most drill presses are very similar and simple. Here is the parts list for yours and here is a manual from Pioneer that shows several models. You should be able to follow the instructions for the Pioneer model that is similar to yours. Compare the parts lists if you encounter differences in the details.
Dec 08, 2009 | Clarke Power Products Clarke 16-Speed...
I need a manual for a craftsman drill press model # 11321371
Manual....Chuck drill bit, select a drill speed, drill!
Aug 28, 2009 | Craftsman Drills
Drill Presses Features
You compare the following features: Horsepower (HP) is the maximum power produced by the motor. Higher horsepower allows you to bore larger holes through tougher material. Drill presses are available with motors from 1/4 to 1 HP. Size/center drilling capacity is determined by the distance from the center of the chuck to the column. Since the press can bore a hole in a circle with a diameter two times the distance from the center of the chuck to the column, the size is listed as twice the distance from the column to the center of the chuck. A 16" drill press can drill a hole up to 8" from the edge of a straight board or at the center of a 16" diameter circle. Variable speeds allow you to drill different diameter holes through different materials without damaging the material or drill bits. Drill presses are available with five to twelve speed settings. The more speed settings, the more versatile the drill press. The table on most drill presses can be raised and lowered along the entire length of the column. It can also swivel 360° around the column for boring oddly shaped pieces. Better presses have large, tilting tables with fences. Quill travel determines the depth to which the press can bore holes. Greater quill travel allows you to bore deeper holes. Depth-stops control the depth to which the quill descends and limit the depth of the hole. Depth-stops are good for repetitive boring and dowel holes. The more precise your depth-stops, the more accurate your boring operations.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Dewalt Delta DP300L 12" Twinlaser Crosshair Drill Press Logo
470 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
