Question about Dewalt DC2PAKCA Heavy Duty Xrp 18V Cordless Hammerdrill / Reciprocating Saw Combo Kit
Hammer Drills differnces
What is the different between a ragular drill and a hammer drill and why is it better then one?
    President:
  • 2,712 Answers
Hammer Drills combine the rotation of a regular drill with a pounding action. These two actions enable the hammer drill to bore holes in masonry quickly without burning the bit.
Posted on Aug 27, 2008
Hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Jul 18, 2012 | Bosch Drills
How sds drill differ from ordinary rotatary drill .what are main basic feature of sds hammer drill
The difference is the working action. SDS drills use a corrugated cams running against each other.
May 30, 2012 | Drills
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
Feb 27, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Can u tell me is it better to use diamand core bit using hammer action or rotary only
Diamond core bit works great on either setting, you will get faster results on the hammer action though
Jan 02, 2010 | Hitachi Dv18dl 18v Hxp 3.0 Ah Hammer Drill
My drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Apr 13, 2009 | Drills
Hammer drills Power supply
There are cordless varieties of just about any type of hand drill, even the specialized hammer drill. These hammer drills work in the same manner as any of the core hammer drills or regular drills. Powered by a set of rechargeable batteries.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Aug 27, 2008 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Dewalt DC2PAKCA Heavy Duty Xrp 18V Cordless Hammerdrill / Reciprocating Saw Combo Kit Logo
241 people viewed this question
Top Dewalt Drills Experts
Tyler Craig
Tyler Craig
Level 1 Expert
Soulvisitor
Soulvisitor
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
