Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Recording From An External Device
Can I record From An External Device?
    Master:
  • 473 Answers
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Posted on Sep 06, 2005
SOURCE:
Recording from line or usb from a computer how can the internal microphones be switched off as it picks up any other external sound on to the music being copied
On a Windows system:
1. Rightclick the sound icon in the bottom right corner and select "recording devices".
2. Next select the device you want to record from.
3. Start your recording software and try again.
Jun 30, 2017 | The Audio Players & Recorders
Tip
How to record Guitar sound on a computer
<p>Line-in <br /> <p>1. Buy a software package for recording music, if your budget allows. Recording music software is specifically designed for recording musical instruments formed. He cannot offer features found in common software audio. Alternatively, an audio recording program for free to get the music recording software than your needs and budget. <br /> <p><br /> <p>2. Buying a guitar cable to your computer if you use an electric guitar. Connect the larger end of your guitar amplifier and the small end into the computer microphone / line-in. <br /> <p><br /> <p>3. For an external microphone when a traditional guitar. Plug the microphone into the computer microphone / line-in. A stereo microphone is a natural sounding audio file, due to the dual microphones. <br /> <p><br /> <p>4. Open your audio recording program, which recognizes the device connected to ensure the microphone / line-in. Pull the cord, again if it does not recognize the device. Change the settings for the recording program to your needs to adapt, you can file type for quality change, and the recording is mono or stereo and audio level. Press the Record button, then started playing guitar. <br /> <p><br /> <p>5. Press the "Stop" button when you finish the game. Some programs can automatically be prompted to save the file; others may be the audio file first. Press "control" and saving "S", if not prompted. <br /> <p><br /> <p>Digital recorder <br /> <p>1. Buy a stand-alone digital recorder, if you do not want a guitar cable or an external microphone. A stand-alone digital recorder is small enough to fit in your pocket and can be placed anywhere without the need hampered by a cable. <br /> <p><br /> <p>2. Set the digital recorder on a flat surface. Press the record button. <br /> <p><br /> <p>3. Press the digital recorder, "Stop" when finished. Connect the recorder to the computer with data cable. Open the device by clicking on "Start" then "Computer" and double click on the recorder in the "Removable Devices". Copy the file from the recorder to your computer. Turn off the burner when you are ready to save battery power.<br />
on Jun 21, 2011 | Computers & Internet
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
Dual microphone issue
drewad125
Technically you can not do this. Most sound cards only support one recording device at a time, especially notebooks. With notebooks usually when you plug in a device it will over ride the build in one.
Now some sound cards give you the option in turn all recording source at the same time so if you laptop would support both mics then you could use this option. The down side is you will be recording from ALL source so you will not want any other sounds going on that you do want in you recording. The steps below will help you check this.
***Note step 4 may not say Analog Mix but if it says mix then most likely you have the option to select all your recording sources.***
1. Click START / PROGRAMS / ACCESSORIES / ENTERTAINMENT / VOLUME CONTROL.
2. Click OPTIONS / PROPERTIES.
3. Select RECORDING beneath ADJUST VOLUME FOR.
4. Insert a check to the left of ANALOG MIX.
5. Click OK.
6. Insert an X beneath ANALOG MIX.
Everything being output via the speakers is now the recording source.
Another option is get a notebook card from Creative Labs as they make sound card. Now if you are doing highend recording you might also look at their highend EMU products as well. I included the links to both there sites.
http://us.store.creative.com/Sound-Blaster-XFi-Notebook/M/B001BS3A3E.htm
http://us.store.creative.com/category/25660134781/1/EMUCreative-Professional.htm
Let me know if you have any questions
Issken
Jan 12, 2010 | HP Pavilion dv4000 Notebook
How do i connect an external microphone to my philips freevents x55. only the built in microphone is working. an externally connected mic does not over-ride the internal one?
Your default recording device is still set on the built-in mic.
In Microsoft XP...
Choose Start > Settings > Control Panel and double-click the Sounds and Audio Devices tab
Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
In Vista, choose Start> Control Panel > Sounds and click on the Recording tab.
In both instances, choose your external mic as the default.
Windows XP 1 Choose Start > Settings > Control Panel and double-click theSounds and Audio Devicescontrol panel.
2 Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
Oct 04, 2009 | Computers & Internet
Acid 7.0 music recorder
It sounds like the software is having trouble locating a recording device. If you go in to the settings for the application, you should be able to select/see the audio input devices. Does the device you are trying to record to show up and is it selected as the active recording device?
Feb 19, 2009 | Sony Acid Music Studio 7 Full Version for...
Playing audio from external sound device.
I think you need to change another audio recorder. Maybe you can have a try Leawo Music Recorder. Leawo Music Recorder is an easy to use but practical audio recording app that could get music off the internet for free for you. It could record online audio file from YouTube, Pandora, Last.FM, Napster, Spotify, GUBA, NPC, MySpace, etc. The other function that makes this online streaming audio recorder program top others is that it could automatically download and add song tags to recorded audio files, including song artist, song album, album artwork, song name, etc.
Step 1. Launch the audio recorder on your PC and you will go to the recording main interface. Click the "Audio Source" icon on the main interface to set audio source firstly. To record online audio and record streaming audio, select "Record Computer Audio" option.
music-recorder-audio-source-settings-t-ykpiva35ohwbucurpfoxfg03-2-0_1.jpg Step 2...
For more detail, check: https://www.leawo.org/tutorial/how-to-record-audio-from-the-internet.html
Aug 12, 2017 | M-Audio Audiosport USB Quattro External...
Help
1. Power ON the recorder, put a cassette tape into the slot. Select EXT 2 as source for the recording when you use an external device as source for the recording.
2.You will need to leave your cable/satellite boxON and tuned to the correct channel for proper recording to occur.
3.
Press z (RECORD) repeatedly to select the recording time length. The recording time can be extended anytime by pressing z (RECORD).
Here are the few possibilities to answer your question. Goodluck!!! let me know if this helps.. thanks
Jan 02, 2008 | Philips DVP3340V
Line in
You need a device that does not come supplied with the player.
Making LINE-IN recordings
Line-in recordings are used to record music tracks in digital format directly from an external player.
1. Connect an external player (like a portable CD player or a stereo system) to your player via the docking
cradle. (this is an optional accessory which is not supplied with your player)
2. Insert one end of the audio cable to the line-out connection on the cradle and the other end to the device
3. Go to the main menu of your player and select Recordings > Start LINE-IN recording.
4. A message Connect line-in will be displayed.
5. Press 2 to start line-in recording, at the same time, start the playback on the device you want to record from.
6. Press 1 to stop recording.
7. Your line-in recording will be saved on your player as a PCM file (.wav extension). You can find this file
under Recordings > Recordings library > Line-in recordings.
-Tha Mp3 Doctor
Aug 17, 2007 | Philips GoGear HDD6330 MP3 Player
When Recording a phone conversation...
plug in the external device to MIC not EAR
Mar 09, 2007 | Olympus WS-100 Digital Voice Recorder
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
333 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
