Question about Arrow Elec Brad Nail Gun Kit
Nail Guns comparison
How much faster is the nail guns compared to a regular hammer?
    President:
  • 2,712 Answers
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
Posted on Aug 27, 2008
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
How do you load nails into a stanley tre550 nail staple gun?
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
Dec 06, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
How many tools will operate at same time
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Nov 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Nail Gun question
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun support
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Nail Gun question
Aug 27, 2008 | Irwin 12" Bar Clamp Multi Position Jaw
Delicate problem
Aug 27, 2008 | Arrow No. ET100 Electric Heavy Duty Nail...
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
Arrow Elec Brad Nail Gun Kit Logo
174 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
