Question about Arrow No. ET100 Electric Heavy Duty Nail Gun
Delicate problem Is it better to use a nail gun then a normal hammer for delicate work?
    President:
  • 2,712 Answers
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Posted on Aug 27, 2008
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
8 penny nails are stuck in gun. How do you get them out?
If the nails are stuck in the rails, remove the rails and fish them out. If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
May 03, 2010 | Dewalt D51844 Framing Nailer
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
Sparks from nailer
Do not worry.This is quite normal. It is the metal driver hitting the head of the nail.There are no electrical components in a pneumatic nail gun so this is pure metal-on-metal strike sparks. You may find it is more visible on certain nails than on others. But do not worry. It is normal. You may find the sparks reduce after time as the driver wears a little or takes on a certain shape.
All sounds normal though. Do not worry :)
Please rate this solution on FixYa!
May 21, 2009 | Stanley Bostitch F21PL Nailer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Nail Gun question
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun support
Nail Gun question
Aug 27, 2008 | Irwin 12" Bar Clamp Multi Position Jaw
Nail Guns comparison
Aug 27, 2008 | Arrow Elec Brad Nail Gun Kit
Arrow No. ET100 Electric Heavy Duty Nail Gun Logo
120 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
EugenesDIYDen
EugenesDIYDen
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
