Question about Bosch 5" 60-grit Sanding Discs for Wood (5 Pack) SR5R060
Circular saw Safety issues
Is it safe to use a regular model if I'm left-handed or should I buy a special one?
    President:
  • 2,712 Answers
If you are left-handed, you must be extremely cautious when operating a circular saw, since most saws are designed for right-handed operation. But if you can, you'll be better off with a left-handed model or an adjustable one (suitable for right-handed and left-handed as well).
Posted on Aug 27, 2008
Where can we buy replacement blades?
Circular Saw Blades from Freud Sold Online - Tools Plus
www.tools-plus.com/freud-circular-saw-blades.html
Saw Blades for Less at Tools-Plus.com. Free Shipping on 1000's of Products.
Circular Saw Blades, ALL Sizes, ALL Brands Sold Online ...
www.tools-plus.com/supplies-power-tool-blades-circular-saw.html
Circular Saw Blades for Less at Tools-Plus.com. ... Shop with confidence knowing that Tools-Plus.com is an Authorized Internet Retailer. 3-3/8" Circular Saw Blades .... Saws and Replacement Blades · Automotive Hand Tools and Equipment ...
Nov 02, 2015 | Saws
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
I need the screw that hold the blade on the saw. its the model # cs185cf
Fixya does not sell replacement screws. Your saw probably uses a flanged cap screw with a standard thread.
Apr 07, 2013 | Kraft Tech Krafttech 12 Amp 7-1/4"...
Can't remove blade on circular saw model 315.10951 A3155. Bolt turns or spins, but won't come out.
This bolt is what called left handed thread so you need to turn it in the oppisite driction as a normal right handed bolt. righty tighty and lefty losey well its rigthty losey. A t this point you need to get this bolt out or the saw it junk you can try slideing something under the bolt something thin and try to get back force on it as you turn the bolt in the correct dericition and see if it will thread out if it dose then you will have to get a left handed tap the size of the bolt hole and retap the hole and also get a new bolt.The tap will cost 30 dollars or so well good luck
Dec 16, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Craftsman circular saw 7 1/4" broken handle
You can buy the handle for 11.59 per side (left and right halves) you can buy them from: www.searspartsdirect.com They have substutited a new part (probably better one) You would have to decide if 25.00 is worth it to fix your saw. You could buy the part and fix it yourself. A new saw like this one is probably not more than 75.00
Jul 18, 2010 | Craftsman Saws
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Jan 31, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I change blade on Ryobi W-660 circular saw. I put some WD-40 on bolt, but it doesn't budge. To loosen, I turn clockwise?
I can't find that model number listed but generally a circular saw is standard thread, the mitre saw us left hand and a worm drive is also left hand thread.
Jan 02, 2010 | Ryobi Saws
The switch is intermittent. The saw has #5375 on the nameplate. I t has the two-handed safety switch where you have to push the red one with one hand and squeeze the trigger with the other hand. Sometimes...
Simply the switch will need replacing and this can be obtained from the mfr or you can get it repaired at a local tool repair center. Get it replaced asap.
Sep 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Bosch 5" 60-grit Sanding Discs for Wood (5 Pack) SR5R060 Logo
123 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
